Any reason these wont fit a 2019? They look great compared to that fake wood they put in them. I've been wanting to do something about that since day 1. I imagine it wasn't hard to install? Just pop out the old and pop in the new?
New body 19 I don’t see why it won’t fit and yes pop off and back in
  • Thanks 1
Just got my trim pieces wrapped. I think it came out great. They said they could not get the wrap to lay down correctly on the radio bezel (I think the carbon fiber print looked wavy on the bends and curves), so still trying to come up with an alternative for that one. I don’t like the silver....Thinking to have a bodyshop paint it either gloss or matte black.
overall, $25 well spent. I was surprised at the low cost...
Thanks. I did some digging and found manuals from 2019 that had that part listed, so definitely looks to be the case. This may just be the best mod yet as I really dislike that faux wood in the truck.
The replacement pieces look amazing. Going to order those for my High Country. Can't stand the cheap interior wood on the doors and center console area.  I don't mind the bronze on the radio and steering wheel though.
Does anyone else’s trim piece look loose towards the back and squeak when you squeeze it? I’ve replaced mine and it still does it? 2020 trail boss
  • 3 months later...
On 5/5/2020 at 10:54 AM, Julio13 said:
Sure got them at dealer but they are cheaper here
Is this the part number for the Carbon Fiber looking ones? I checked the website and it gives the names of several this one included but nothing says carbon fiber at least not that I could find??
The steering wheel and center bezel from the badlander picture is probably hydro dipped vs wrapped. Hydro dipping uses an actual carbon fiber layer and usually gets clear coated when finished. You can see quite a difference between those pieces in terms of color and clarity vs the OEM faux pieces. Wrapping them in vinyl is probably the least expensive option and shouldnt be difficult for most to do. It wont look any better than the OEM pieces but it will cost a quite a bit less and is reversible without having to keep the old parts laying around.
Im actually thinking of painting/covering the silver trim ring around the center console where the cup holders are which will mean doing all of the silver to keep it matching. Not sure if others have run into this but the mid day sun hits that trim ring and can be a bit blinding and comes out of nowhere depending upon the direction you are driving and how the sun hits it. Same for having a phone in the charger. Ive already started to mod the center arm rest to support induction charging to resolve that.
Yes they look black but fade to carbon fiber
  • 2 months later...
On 5/6/2020 at 11:35 AM, Julio13 said:
That’s the bad lander edition if you look close it’s carbon fiber
I believe it's hydrodipped not real carbon
  • 1 year later...
I have a 2019 Silverado High Country. I was on the highway, and I saw another high country with a chrome or polished door trim with Silverado stamped on it. The amazing thing is it looked like the Cadillac escalade door trim. Can anyone help me locate this product, Thanks in advance.
I had a chat with TuscanyAutomotive.com and they do not sell parts. Only custom trucks. Not interested in a custom built truck, that's what i am doing to mine. Chevrolets parts book lists 11 or 12 different finishes for interior trim pieces, door handles, radio head trim, A/C -Heater vents, console, etc. My 2021 Trailboss Custom came with the graphite fades to black door pull panels. The dealer removed the crummy woodgrain panels on the front and rear doors and installed the black to graphite panels when I took delivery of the truck. I believe this was part of the Midnight Package. I want to replace the radio head and the steering wheel trim with a carbon fiber or graphite fades to black panels. Does anyone know the GMs color description of these parts? My trucks VIN is listed as black for the interior trim but the panels around the radio head and steering wheel are the common silver that i see in most trucks. Any help or direction would be appreciated.
  • 7 months later...
I found your post today(11-25-2022) as I also installed the trim pieces. And yes mind also squeaks. Did you ever find a solution to squeak?
    ncleg
    ncleg
  • Who's Online   2 Members, 0 Anonymous, 1,477 Guests (See full list)
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
