31 minutes ago, Racerx944 said:
I didn't end up with his truck.  I read his post and how he fixed his problem which he indicated was "common" for our trucks.
The contactors are likely not difficult to replace other than lowering the battery pack and opening the pack without shocking yourself.  If I had to replace mine, I would do it myself.
The document you provided about the A123 battery pack shows an Electrical Distribution Module (EDM) and this is what a contactor looks like (round with posts on top).
Yes and it also shows that contactor bundle as well. I think it's a great tool to visualize how everything in the pack is put together.
How much did they quote you on replacing the contactor and have you contemplated doing it yourself?
I'm waiting on the quote from them as well as the parts quote. I would absolutely change it myself, but pulling the battery safely at my house isn't going to happen. I'm also dealing with my '32 needing to get fixed after the suicide door flew open on me. 20220616_203902.thumb.jpg.a29aca2bea71116c88caba10416593aa.jpg
Just got the quote a moment ago. Let's see if the attachment works. I've been having trouble all of a sudden.
Slim
Edited by Slimsalabim
Attach pdf
Slim
Pretty strange they charged you for a contactor and EDM.  I figure that the contactor would be in the EDM.
Now you just have to get a quote for installation.
Suggestion is to take personal info out of the invoice.  Maybe I am just more paranoid.
Edited by Racerx944
Good catch. Updated it. They probably know I'm not using them to fix it so they bypassed that quote.
Slim
Slim
I hope the dealer will give you a good price though I would imagine it won't be cheap since not many people want to work with HV traction batteries.
I have to charge the battery in the van somehow.  It is one of the very early prototype of their prototype fleet.  It has an iPad in the dash and only has 2400 miles with original tires from 2013.  If I can't figure out how to get it to run, I will probably convert it to gas and take the EV parts to use in another conversion to all electric using only batteries without an ICE.
If I have to take apart the battery pack, I will post pix.
51 minutes ago, Christian Bracamonte said:
Got my quote too,  ow waiting for Tammy to answer back…
also anyone can recommend a home charger?
I jumped on that deal right away.  Look around for a replacement.  It will cost you twice the amount.  Even if you have the motor rewound, I was quoted $395 for the rebuild on that pump and I doubt it will be the same as a new one.
I used the EVSE from a 2016-2019 Chevrolet Volt.  The EVSE will accept both 120V input or 240V input to charge at level 2 so I made an extension cord that puts out 240V with a 120V female receptacle into the Volt EVSE to charge it at level 2 (I believe @ 3.3KW).
Everything at my house is powered by solar panels and Li Ion battery including the car charging.
Edited by Racerx944
That screen is crazy. I put an aftermarket in mine, but I it didn't monitor any battery stuff.
Have you checked this place for batteries?
https://www.thunderstruck-ev.com/used-a123-pouch-modules.html
That display is original from VIA Motors.  Same with the iPad.
I bought out the solar inventory out of one of the biggest solar installers in San Diego when they went bankrupt so I am sitting on about 150KWH worth of used LG Chem RESU batteries.  I am planning to experiment with an external battery pack that is charged separate from the truck so I don't have to mess with the vehicle electronics.  I want to "tap" into the DC input to the DC/AC inverter/charger , which I believe powers the motor controller downstream.
If I can't find a 112S BMS (doubtful), I am just going to balance the pack manually initially and use it without a BMS.  I figure the motor controller will limit how much power it pulls from the battery pack.
I will have to use LED voltage display on each of the 7S battery blocks (16 blocks of 7S each) to get 396V to make sure the battery doesn't go out of balance.
Edited by Racerx944
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
