Shock & differential spacers
At what point do differential drop spacers & shock extenders become a must when adding front end height?
I want to add an inch to both ends of my truck; the max I want to add to the front would be 1-1/2”. I like the rake, and have garage door clearance issues.
This is a pretty complex question, shock spacers depends upon the shock that you’re using and it’s total travel.
Differential drops are really only needed when your CV axle is at too great of an angle to operate without binding. I found that when lifting my truck front end more than a couple of inches the cv angles were to the point of the ribs on the boot were rubbing 5907490da26a520246c3ff0e5e39dc81.jpg
They were never binding but was at the limit that people told me it was borderline bad. I sit at about 12-15* from horizon, now. I used a 3/4 spacer and it improved enough I was happy. I don’t have an after picture.
Differential drops are really only needed when your CV axle is at two grade of an angle to operate without binding. I found that when lifting my truck front end more than a couple of inches the cv angles were to the point of the ribs on the boot were rubbing 5907490da26a520246c3ff0e5e39dc81.jpg
What’s a “two grade?“
Assume that stock or stock length shocks are used.
I understand excessive CV joint angles. My question was at what point spacers became necessary. To put it differently & more directly; would differential drop spacers be needed after 1”-1.5”?
I read it as ...too great...
Sent from the demons in my head
Hard to give a definitive answer, but when I was looking to level the front, I jacked up the front and took pics at different heights.  Thread linked below.  I ultimately decided to drop the rear with shackles.  But I did end up cranking in 3/4" of lift on the front.
If I were going to raise the front, I would go 1.5" max without further mods.  Anything higher than that and I would drop the diff, buy new UCAs and get shock extenders.  Basically the full rough country front leveling kit.
https://www.gm-trucks.com/forums/topic/236884-level-or-lift-2015-2500hd/
Thank you. I’m not going to drop my rear end, though. If I’m understanding you correctly, a +1” change in front doesn’t necessitate spacers- that’s the kind of info I’m after.
IMHO, a +1" change in front height using the torsion keys doesn't necessitate spacers.
Ha, I feel compelled to reply, that's my truck's suspension pictured in that link to the other thread.
Everyone is saying the right things here. If your shock has longer travel then a stock shock, it may not need a spacer at all. A stock shock, you may want to start adding length in the 1.5 to 1.75 inch territory.
A diff drop is dependent on the rubber fins touching each other as mentioned above, they'll wear out where they touch.
Yeah it was voice to text. Ooops. It’s kind of a judgement call. What do you deem as acceptable.
Good advice here. On the stock shocks, you can raise the front around 1" without needing to add any hardware. I had a slight bumping/thumping over big bumps and speed bumps with a 1.5" lift in the front (7-8 turns on the factory keys). I added shock extensions, and the noise went away, so that tells me 1.5" is about the limit for factory shocks. If I had a do-over, I would have went with something like the Rough Country 3" kit. I would have installed all the parts, but kept the front around 2.5", which would be just enough to run 35" tires.
Thank you; that’s good feedback ?
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
