I have intermittent issues with my audio on my “radio”.
2020 GMC 2500HD AT4 (Diesel, but that shouldn’t matter).
The sound will cut in and out. Sometimes for a few seconds, sometimes for a few minutes the sound will go from whatever volume I have it set to silence.
The audio source doesn’t matter, I have the issue with FM, XM, iPhone music via Bluetooth, phone calls, the Weather app...
I have taken it to the dealership twice and they have tried software updates. Once was a newer version, once was reverting to an older version.
The dealer did acknowledge they had observed the issue.
It does seem to happen more often when the vehicle is hot. I live in Phoenix AZ so it’s in the low 100’s for highs right now.
Anyone else seeing anything similar?
Yep I'm having issues with audio as well. Mine is a LT with upgrade radio and while driving the sound quits and I have to change stations to get to work,  then when starting the truck audio does not work and have to change channels to get to work.
Have a 2019 custom 'Trail Boss' and I have been having issues with the radio since 600 miles. The screen wont come some times, and other times the touchscreen wont work. Its something different almost every week, Ill be driving with the radio on and the screen will go black and stop working all together. The Infotainment has the base 7" screen, when I start the truck and the radio works its Christmas for me. I have had the truck into the dealer 4-5 times with the radio and they keep telling me its a programing issue and GM knows about and are working on a repair, but nothing at this time.
Additional info...
My screen always works, only the sound cuts in and out.
Infotainment System Update v148 from Dec 2019
When the radio is working, sometimes the screen wont work, and Im stuck with the station I had on last.
Ive talked to GM customer service and they say they are aware of the issue....Thank you for knowing about an issue your having with your trucks.
I'm having similar (but not exactly the same) problems.  My service department claims that this is a problem that SiriusXM needs to resolve.
I could understand if my problems were always with XM, but the audio issues arise with no regard to the selected audio source.  My truck is in the shop for the 3rd time for this issue.  If this was a software issue, it should be quite prevalent.  Instead, there are a few of us (according to GM) having these issues.  I told them to start ripping out hardware and replacing it until the problems go away....I'll update if they find a way to fix my problems.
My problem is definitely not Sirius XM as the source doesn’t matter. FM / XM / Phone Calls / Steaming audio (cuts in and out whether the phone is connected via Bluetooth or plugged in).
It’s almost like the connector isn’t plugged in all the way and there is an intermittent contact.
Mine has been in twice for this problem.
I have a 2020 that I just got a month ago. On one occasion, it was a warm day so we had the windows down & radio up. Well it stuck in the loud position & we couldn’t get it to turn down. Tried restarting/resetting everything. Finally, we just turned the radio off & drove home. Turned the truck off at home, went in to get my husband & when he came out & started the truck, the problem had resolved itself. The other two times, it was black screen when starting the truck at home. Had to turn the truck off & back on.
My audio cut out problems seem to be worse when the temperature is hot.
The bad news for me is that I live in Phoenix.
Jay, have you had any resolution for your audio problems?
Between having my truck in the shop and not driving much lately, I cannot give you a definitive answer.  It seems better, but I cannot say for sure.  I'm heading out on a cross-country trek tomorrow, so I'll find out for sure either way.
When I did get my truck back yesterday, I noticed some subtle differences in the user interface (e.g. incoming phone call screen is a bit different), so I am thinking they updated my audiovisual software.  Fingers crossed....
Sounds like the same/similar problem I'm having with my 2500 gas Denali.  Upon startup siriusxm will sometimes constantly search for satellites (never fixes itself) or any of the infotainment in regards to sirius is unavailable.  Problem starting to get worse, waiting to hear back on dealer. Kris
My wife and I drove 1200 miles over this last long weekend and the issues were very minor.
We had the “radio” set on a Sirius/XM station and we commented on how few times it cut out.
I’m starting to think it may be heat related.
I live in Phoenix AZ and the temps have been in the 110 range with the truck interior much hotter when I get in. Since most of my trips are short the system doesn’t cool down much.
Our trip was up to Flagstaff and on to Durango, Silverton and Ouray CO. The weather was much cooler so possibly that helped.
We drove back Sunday afternoon and today the audio was cutting out when I was speaking to my mother on the phone. I switched the phone audio from the truck to the phone handset and the audio started working well again. It is cooler today but still 106...
I’m interested in hearing about how Jay’s system worked on his trip...
There is a service bulletin out on the issue. effects a lot of GM products. Unfortunately no fix at this time.  Once they find a fix they will either update it over WiFi or with a stick you can plug in .  ETA unknown at this time.
Edited by airwolf912
  • 4 months later...
I picked up my truck this afternoon after taking it to the dealership for squeaky brake pads (TSB took care of it).
I took a recording of the radio sound cutting in and out while playing XM/Sirius, FM and my phone.
They were able to replicate the issue and try the solutions suggested by GM Tech Support.
They wound up replacing the head unit and so far it has been working great.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
    • Same here, first I bought a few filters to get me going right after I bought my truck to do some short distance initial oil changes, then realized I could buy a case lot for less as they drop the price if filters or trans oil etc is bought by the un opened case lot as well as the discount for buying the vehicle there. So I have filters for a while but its good to know going forward, knowing to expect it to be a different part number and looking filter at the dealer and not be confused over it and think they are handing me the wrong part.
    • Saw Inglewood was in the National New last night for hail. Allot of hail. front end loader level hail. 😱
