Sorry if this is a duplicate post. I have a 2015 Silverado that does not have the GPS module installed on it. Does anyone know of an application I can download that would send my GPS map from my phone to the center console screen?
Sent from my SM-G965U using Tapatalk
Android Auto should fix you right up.  It will connect your phone to your dash screen by USB cable and allow you to use Waze, or Google Maps.
How do you connect your phone to show its screen? I don't have an  android device
Android Auto and Apple CarPlay compatibility for the head unit was added in 2016 models. You won't be able to project to the stock unit on a 2015.
Hmmmm ... Didn't know the year limitation.  Is there a bluetooth solution available for those models?
Even some 2016s were built without a capable HMI because of supply shortage. There is a thread on the forum discussing it.
Bluetooth will not work for projection. The 2020s don't even have wireless projection yet. You could use Bluetooth to connect your phone audio which would then catch any audio directions your phone broadcasts. You could get a phone cradle that puts it up by your display if you want it in that area. Otherwise you'll have to do some customization with a newer HMI or aftermarket.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 1 Anonymous, 524 Guests (See full list)
