2015 fuel pump interchangeable
I have a simple question does anyone know what year is compatible with a 2015 chevy 1500 pick up fuel pump with sending if there are any
look at online parts sites, such as rockauto.com, find the pump you need, then look up the part number again and it should tell you what applications it's for, and that will tell you what years are compatible.
GM parts websites will show the compatability of parts much better than rockauto imo, just cause it is a GM parts website, specifically for GM vehicles. They'd regulate the parts and info much more than rockauto with millions of parts for tens of thousands of vehicles.
Sent from my SM-N975U1 using Tapatalk
Welcome to the site.
This will fit the 2014 - 2018 1500's:
Fuel Pump - GM (13513407)
Really?  That one pump works on all 1500's?  I don't know anything about that model, but RockAuto lists 8 different ACDelco pumps (one of which is the one you specified), with a variety of ports on top, for a 2015 Sierra w 5.3 engine.
I think the O.P. first needs to figure out what specific pump her truck uses...
Yes, direct from GMPartsdirect.com.
This Part Fits
Make Model Year Body & Trim Engine & Transmission
Chevrolet Silverado 1500 2018 Custom, High Country, LS, LT, LTZ, SSV, WT 4.3L V6 - Flex, 5.3L V8 - Electric/Gas, 5.3L V8 - Flex, 5.3L V8 - Gas, 6.2L V8 - Gas
Chevrolet Silverado 1500 2017 Custom, High Country, LS, LT, LTZ, SSV, WT 4.3L V6 - Flex, 5.3L V8 - Electric/Gas, 5.3L V8 - Flex, 5.3L V8 - Gas, 6.2L V8 - Gas
Chevrolet Silverado 1500 2016 Custom, High Country, LS, LT, LTZ, SSV, WT 4.3L V6 - Flex, 5.3L V8 - Electric/Gas, 5.3L V8 - Flex, 5.3L V8 - Gas, 6.2L V8 - Gas
Chevrolet Silverado 1500 2015 High Country, LS, LT, LTZ, SSV, WT 4.3L V6 - Flex, 5.3L V8 - Flex, 5.3L V8 - Gas, 6.2L V8 - Gas
This Part Fits
Except that there are 7 other ACDelco pumps, that goes into other 2015 Sierra 1500's.
gmpartsdirect (which has a poorly done website), drilling down for a 2015 gm sierra 1500 w 5.3 WT, the list next to the parts diagram lists 4 different pumps (1 midway through the list, 3 more at the bottom of the list).
13510918
13513409
13513408
  13513407
13510918
13513409
13513408
  13513407
OK, so maybe she should check to see what her truck has in it now?
Not much info from the OP other than a 2015 Chevy 1500.
Nor has she replied back.
