Hello all...Has anyone been able to get an Ipod classic to work correctly in a 2020 Sierra with the 8" screen? Music plays and I get contexts, but can't browse. There's no browse icon and voice recognition doesn't help. Scrolling thru the cluster menu, the " browse Ipod" is shaded out and I can't select it.
I thought I was the only person still using one! I have an ancient iPod using Bluetooth to connect to the truck. I just keep it charged and working well. I have not tried the cable connection.
Does the classic still receive updates from Apple?
Yes, but didn't seem to help. My buddy tried his ipod touch (6th gen) and it worked flawlessly. So I guess I'm gonna have to suck it up and get 1.
Edited by shadysneed
I have a classic. Up until 2017 I’d go through my usb and could use my steering wheel control to make it work. It would show on my screen. Same with my I- phone. Of course the I-phone is blue tooth, my classic isn’t. It’s too old.
I had the same issue. Classic (or original) iPods have a small hard drive while newer models have a solid state drive. Only the solid state drive is readable to for browsing, etc. Both will play, but you have to manually change your selection with a hard drive model.
Hi everyone, Not sure if this has been answered. I am new to this forum and went from a 2019 Chevy Colorado from hell to a 2020 GMC Sierra Denali in March 2020.
I had the same issue with my Colorado and it also occurs with my 2020 GMC Sierra.
Here is the fix that corrected my issue.
on the Iphone
1. go to setting
2. click sound and Haptics
3. Make sure the tab "Change with Bottons" is off (not green)
4. Set your ringer volume to the level you would like to hear it at.
5. this disables the side volume buttons but things should work now.
Before this I would set my ringer to a mid range level. Once my bluethooth connected I could see the volume drop. When I disconnected from bluetooth is remained silent until I used the side bottoms to increase the volume. Now I have my volume preset and yes the phone volume goes down when connected to bluetooth but raises again when to my set volume level when I disconnect from bluetooth.
Hope this helps.
ST
  • 3 months later...
I just bought a 2020 Sierra 2500HD crew cab base model (no electronics on steering wheel).  I have a classic ipod and plug it into the dashboard usb, nothing happens.  I confirmed my ipod is running latest software.  My samsung phone plays fine via bluetooth.  Any ideas with ipod?  Thanks!
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
    • I removed the OE running boards.  It looked so much better.  I wish I took them off a long time ago.     I had to put something back on for my wife.  I wanted Westin Sure Grip Running Boards but they are very pricey, like $600 plus.  I was going to go with the Ionic 41's like I had on the 2019 Silverado but went with Westin Outlaw Drop Steps instead, about $200 cheaper.  They are sturdy and functional but not super crazy about the look, but it works.
    • It's all a crock of 💩
    • I had a Gen5DIY DRL relocate harness from a 2022 1500 that I saved. I had Gen5DIY modify the harness for my 2024 Silverado 2500. Plug n Play, worked perfectly.    Here's a video I made for the 2022 1500 truck. The install is more or less the same on a 2500.    The harness relocates the DRL tot he top amber turn signal on my 2500.
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
