Misfire
Now as I’m sure there has been a thousand posts about this subject. I did a search with no luck to what’s going on with my issue
i have a multiple cylinder misfire that I can’t seem to track down.
i have changed the following
cam (tsp stg 3)
phaser lock out
lifters
dod delete
valve springs
pushrods
fuel rails and injectors
spark plugs twice
wires
checked all grounds.
I’ll list the grounds I know about.
1 pass head to coil harness
1 pass head to coil harness also chassis
1 pass block by starter
1 alt bracket
1 driver block above vacuum pump
I’ve done cylinder temp checks and they are all over the place.
And know cyl 7 is not firing at all
plug came out smelling of fuel but no heat or carbon marks.
please help
Safe to assume a tune was done and all that to turn off all the AFM/DoD stuff first?
Did you move the coils around??
Is there power at the #7 coil?
Yes dod, afm have been turned off. Tuner said it’s not mechanical as in cam timings as no codes present.
I haven’t moved coils around as that’s my next move. But what’s weird is the exhaust temps. Which makes me lean towards multiple misfires
as for #7 having power I haven’t checked
attached is a pic of cylinder temps
