Hey guys, just asked the dealer to put in an order for a new 2020 2500 and they told me there normal lead time was 6-8 weeks, but there not sure how long with the COVID. Anybody have a truck built recently? How long did it take. I guess I am not in any real hurry, just curious. Thanks.
Well I don’t see how they put in an order for you. The order deadline for MY 2020 was back in May. So they could only put in a order for a 2021. Unfortunately the production start up for MY 2021 is sept 28th. So if they did order one for you it’ll be a 2021 and I wouldn’t expect it till oct/nov. I was actually at my local dealer today asking about the same thing because I sold my truck yesterday and now I feel like half a man (truckless)
Well that would have been great info for him to tell me. The salesman said nothing of the sort. I thought the build sheet he gave me said 2020 on it but I will have to check it out when I get home. I am in no rush so Oct/Nov is cool with me but he didnt say anything about it not being a 2020...
Did you order a CC. If so you could still order one last week. If its a Dbl cab then it'll be a 2021
I did, crew cab 4x4 SLT loaded.
Wed last week it was still avail so hopefully you are G2G :)
Spoke with the salesman I worked with in ordering my truck yesterday, and he said everything went through as far as he can tell. So I think like the other guy in her said it depended on what you were having built. He said when I mentioned this, that it did, because they cut off body styles and colors that they are no longer going to have in 2021 earlier in the year.
Well that’s good news. Maybe my dealer is full of $*^t. They don’t have what I want so they where trying to sell me something. Maybe they only have an allocation for a 2021 and that’s the line of bs they fed me. You never know with these guys unfortunately
The guy also told me they don't give out the build # anymore for you to track. Do you have know knowledge on this matter? He said I would call every 20-30 days and he would look it up, but I would love to be able to look it up myself whenever I want.
hopefully it goes thru....so many issues with ordering and guys waiting months before covid....and salesman dont know ****** it seems for most part...i would think good luck getting any 2020 HD  this late.....doesnt matter what they say only what they can produce and hasnt been good so far
I ordered early in March. TPW is 8/10. I’m concerned about the quality now with so many workers being out sick.
I don't know what TPW is sorry. Can you explain? Thanks.
Target Production Week
Its been a long wait. Trying to confirm with my dealer its still on target.
Oh wow, so you ordered in March and they are not slated to start building until 8/10, or is that the targeted week for it to roll off the line?
I think the time line depends alot on what exactly is ordered. I ordered my 2500 crew cab LT gas in mid April(during the shutdown).  It arrived at the dealer mid July. I was surprised by how quick all things considered
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
