Installed LoMax tri-fold hard cover tonneau this am. Moderately easy install. Needed my buddy's help to lift the cover onto the truck bed. Not as young or strong as I used to be. Definitely not a one person job. Excellent fit and finish. Sleek looking tonneau.
  • Like 4
Sent from my SM-G981U using Tapatalk
My cover is at the dealer for the clip recall right now. So I haven't even seen it yet. They're gonna install it on Friday. Is the thing waterproof? Is it the same tri-fold they install at the dealer?
Looks very nice......
I have the BakFlip MX4, love the low profile and versatility.
LoMax and BakFlip seem to be the brands of choice.  I believe that dealers use various products.  My dealer had nothing in stock and wanted about $1200 installed.  I paid $833 + tax and installed it myself.  As for waterproof?  I don't think any tonneau is completely waterproof and you may experience some leaks depending on speed, intensity of the rain, wind, etc.  So, make sure to cover your other half's gear with a lightweight tarp or similar.  However if it's properly installed it should do a good job of protecting your gear.  If i lay down in the bed and look towards the corners near the cab, I can see a speck of light about 1/4 inch in diameter.  Allow the cover to settle on the bed for 72 hours or so and check again.  I have numerous items in my garage that can be used to plug the tiny spaces.
I did some looking around and it seems like the dealer installs the Rev brand. I'll find out when I go in tomorrow morning
Yes, REV is the dealer brand.  I was told they had supplier issues due to COVID so none were in stock at my dealer.  There are some reviews on this forum so you might want to check it out.
Edited by LowCountrySLT
Ps:  I discovered that the retaining clips weren't properly seated on the rail at the front (cab) end thus creating peeks of daylight in the corners from underneath.  Pulled her loose and reattached the retaining clips and now the tonneau is very tightly fitted with no daylight visible from the bed side.  As with anything automotive, the proper fit and install is critical.
And this afternoon FedEx delivered my BedRug and a couple of cargo divider bars.  That's all the aftermarket toys for now as I'm getting the evil eye from you know who!
Assuming you’re talking about the LoMAX, can you please explain what you mean about the clips that you mentioned? I installed my LoMAX a while back and don’t recall installing any clips. Mine has a slight leak at the front corners, so wondering if that could be the issue. Thanks.
On the front underside of the cover nearest the cab my LoMax had 2 preinstalled clips that are designed to fit (clip) underneath tabs on the side rail. This is what holds the cover in place at the front. My tonneau is LOMAX Tri-Fold. I don’t think under any circumstances that it’ll be completely leak free but I expect any leaks to be minimal. Best of luck.
Ok thanks, I now know what you mean. I also have the LoMAX trifold. Also had one on my previous F-150. Love them!
I'm looking to order one soon for my AT4 and I'm curious...are any of these hard folding style tops have a quick release to remove when necessary or are they pretty much on for good without removing all hardware?  I have no idea what brand but I have seen some hardtops that have a quick release option to remove when needed but not requiring hardware removal.
I’m running the Gator Quad Fold. On all these they have a provision to either fold it flush with the back glass or at least fold to the last section. My gator can be removed completely with a pair of knob type screws from under the last section. I’ve never had o remove it so far as I can prop it up against the rear of the cab with included strut rods to get access to the full bed. I’ve not had mine in many intense downpours yet but lighter rains it’s been completely dry inside.
The LoMAX has a quick release to remove the cover. But the rails stay attached to the truck bed.
Hi Guys,
I'm in the market for a tonneau for my 2020 LT trail boss and can't decide on the Hard Flip of the Hard roll up.
Anyone ever compared them?
also,
Is the tailgate still able to open automatically with the LoMax/Gator or MX4?
Thanks
Barty
    • thanks for coming back and posting what the fix turned out to be.
    • Only TAN I have for the product was at 5K in service miles and it was 2.71
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Note: please disregard fuse sizes. Main fuse will like be 25A, all mini bus fuses will likely be 10-15A   Cheers
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
