I have about 9,500 miles on this new truck and I can not believe how noisy the brakes are! A little noise is fine, but I have never had a truck (or any other vehicle) this bad. It sounds like it's coming from the rear passenger side and intermittent - it doesn't do it all the time. It's worst during lighter braking - getting on them harder quietens them up. Then - it won't make any noise for a while - just to start up again. I've taken it to the dealer and of course, they found nothing wrong. I pull up in front of customers homes and if they are outside, they are like..."dude fix your brakes". Sucks to have invested in a new truck that sounds like a beater.
Anyone else have this issue???
That sucks man. Sucks the dealership won’t make it right - squeaky brakes are usually a pretty easy fix, unless there really is something wrong with the caliper/rotor, in which case you should have warranty coverage. A new set of pads on that side shouldn’t be too much for a dealership to make this right on a new truck sale. Take it back, hopefully they can reproduce your problem and go further than your first run at them.
My 2018 had squeaky brakes, and after the third visit and complaint the dealer replaced the front pads.  It fixed it for a while and then started up again but not as bad.  I traded it for a 2019.
There is a bulletin for this. The fix is to replace the pads, different material.
There have been some reports that new pads didn't fix the problem
mine squeek in morning for first few stops then goes away......
Thank you for this! I found it: Bulletin No.: 20-NA-020
I have a 2020 Sierra AT4 HD.  Brakes started to squeal at about 2500 miles.  All 4 wheels did it at different times and sometimes all at the same time.  Dealership said its normal brake noise.  I laughed....it sounds like a garbage truck on Sunday morning.  Really loud and embarrassing after spending $80K on the truck.  They refused to do anything about it.  I've always done my own brakes so I just took them off, cleaned them and put anti-squeal compound on the back.  Still squealed.  Tried again with a different compound....still squealed.  Finally I took them off and since they are squared off at each end unlike most pads I've seen which have a 45 degree chamfer on them I took an angle grinder on the ends of each pad and created that 45 degree chamfer and problem solved.  I also used an anti-squeal on the back of the pad for extra dampening.  I think the squared off pad edges just vibrate at low speeds.  Don't expect your dealership to do anything.  Hope this helps.
Hey man - I printed off the bulletin mentioned in this post and took it to the dealership - they changed out all 8 pads with an updated material as a warranty repair (probably softer material). The breaks are perfectly quite now!
Edited by Mike Fetherling
Glad to hear it.  Hopefully they don't start up again down the road.  If mine start squealing again I'll have to replace them.  I looked for aftermarket pads, but they don't make any yet that I could find.
UPDATE:  My brakes started to squeal again so I took it back to the dealer with the service bulletin and they replaced the pads.  It was quiet for 4 weeks and started to squeal again.  I took it back yesterday (dead battery again too) and they said they could not reproduce the squeal.  (it literally does it every time I drive it.)  I showed the service guy a video I took the day before and he said even if they did hear it they couldn't do anything about it because they already replaced the pads.  I asked about replacing the rotors and he said GM would not pay them to do that so they won't do it.  Seems like they aren't allowed to think outside the box to fix the problem.  I'd be happy if they just turned the rotors to see if that works.  I guess I have to pay for it myself.
UPDATE:  I contacted GM Corporate at 800-462-8782 and told them about the brake squealing issue.  The assigned my case to Courtney who never called me even after I left her two messages.  Due to lack of communication GM escalated my "ticket" to a different office and they have now assigned a "TAC team" to work with the local GMC dealer to fix the brakes and a dead battery problem.  They're giving me a loaner car which makes me think they are going to have it for a while.  Hopefully this fixes it.  They are now squealing not only at low speeds, but when I apply them at 20-30 mph.  So frustrating!
Edited by RossEGCA
Thanks for this article guys, I have been having the issue and the dealership forgot to check the brakes when I went in for an oil change a couple months ago. Drives me crazy to hear the brakes so squeaky. I have 20k miles on mine and it's been doing it intermittently for the past few months. Always happens at low speeds with light braking, like in traffic or pulling slowly into my garage. At first I thought it was because I live off of gravel but my 2012 Silverado 1500 never squeaked like this. I have printed out the bulletin as well and intend to bring it in with me on the next oil change so that hopefully they'll take care of it for me.
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
