Some of the single wheel trucks you see will be 3500'd -- which gives them a little higher rating.
A bigger improvement in ratings comes with the dual rear wheel configuration.
The ones I’ve seen and I’m mentioning were 2500’s  i know with a 3500 it will be more  ?
I just picked up my 2500HD AT4 yesterday and plan on getting a fifth wheel in the next 2-3 years. There are plenty of fifth wheels that our trucks are capable of pulling with plenty of left over payload. Grand Design makes at least two or three in the 30-35 foot range. I like the fact that when you know your capabilities and max weights it can limit the amount of options that you can pick from because there are so many options out there. My two cents on toy haulers are  you are getting the best of both worlds, RV and a trailer for your gear in one. The toys themselves are heavy so make sure you know that weights of all the stuff going in the toy hauler. Also be aware that toy hauler fifth wheels are designed to have the toys in the back so unloaded tongue weights can be higher than actual weight to make it easier to calculate GVWR. In my estimation you may have to get a smaller toy hauler to stay safe.
I disagree on the having to get a different toyhauler. I am well within my limits with this one and have more than enough power to do the job. Congrats on your new truck also. I love my 2500hd LTZ
  • 4 months later...
I am looking to buy a 5th wheel toy hauler gvwr is 19,000lbs
i have 2020 2500 6.6 duramax hd denali with airbags.
does it mean that I am overweight 500lbs.
If I keep it lighter by semi empty black, gray, gas, fresh water liquids would I be ok?
I'm far from an expert on towing here, but by the time you load up your camper with supplies and add your toy in the back, I believe you'll be pushing the limits and capacity of a 2500.
The new g.m. trucks have more payload than competitors. Payload will almost always be the limiting factor for towing. I pull a 12k 5th wheel with a gas 2500 and it is well within all limits.
I understand what you're saying, and your 12k is one thing, but for the comment above me asking about pulling a 19k toy hauler with a 2500, that is going to be too much. No matter if it's a Duramax or not.
Just remember how the trailer ratings are calculated by SAE 2807.  Base vehicle weight + 300 lbs passengers + 100 lbs cargo + hitch weight (forgot the exact weight think it is 125 lbs) + 15% pin weight.   Then the trailer weight is raised until it hits GVW, RGAWR,  OR GCW.  So if your passengers, cargo, or pin weight is higher, your max trailer weight is lower.  I generally tell people if you get to about 80% of max number so should be good, over 80% you better find some scales and start weighing truck and trailer.
#iworkforGM
Figuring 20% of trailer GVWR as pin weight (which is an accepted rule of thumb for 5th wheels), that trailer would practically max out my 3500's payload rating. So, your 2500 is going to be 500-600lbs overloaded BEFORE your hitch, stuff in the bed, passengers, dog, etc. You're going to have to hit the scales to see what the actual weights are before you'll know for sure where you are. Air bags are for leveling and ride and don't change your payload capacity. One thing that could help is a light weight hitch. I have the Andersen Ultimate which only weighs 40lbs. But, that's only going to get you 100-200 pounds - at the most - depending on what hitch you have or are contemplating. For me, it was a big change from my Pullrite Superglide that required a hoist to get in and out.
Edited by Njmurvin
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
