I searched for this prior to starting .....sorry if there is a thread out there, but I couldn’t find it searching on several key phrases.  All that seems to come up is the auto-start-stop feature on the 1/2 ton vehicles.
I’m trying to determine if there is a way to remove the auto-stop feature on my 2020 Chevy HD Duramax?  Fortunately, my sweet little dog was in the truck for less than a minute after the truck miraculously automatically stopped.  I was not informed of this “feature” at the time of purchase.   If one of the moderators can point me to a thread where I can learn more, that’s appreciated as well and you can cancel the post.
Thanks in advance for your feedback.
Kelly
There’s no way to disable it but if you put it in neutral with the parking brake on in won’t shut off
Thanks, brclark82.  Appreciate the advice.
2 hours ago, Ray Pickle said:
Wow I did not know G.M H.D. diesels had stop/start. Learned something today! Gasser does not have that.
I don't think it has stop/start.
I believe what the  OP is referring to is an idle timer that shuts it off.
They do have a self cooling feature that, if it's been working hard, MAY restart it and idle for up to about 15 minutes to cool itself.
From 6.6 Dmax supplement:
If the Action Required - Idle Vehicle To Cool Engine DIC message displays, do not turn the engine off.
Keep the engine running until the message goes away.
Intended Vehicle Use: After a Heavy Towing Event
If equipped, when the vehicle is turned off after towing heavy loads, the system may automatically restart the engine. A chime will
sound and DIC messages will display. The engine will automatically turn off after 10– 15 minutes of run time or if enough
cooling has occurred.
If the DIC messages display after the vehicle has been stopped and placed in P (Park) with the engine still running, remain in the vehicle with the engine running until these messages no longer display. It may take up to 15 minutes of idling. Do
not park the vehicle in an enclosed area if the messages display.
If the system determines that the engine should be restarted and the ignition is turned off, the engine will turn off and then automatically restart. If the engine is restarted,
DIC messages display and chimes will sound. The vehicle cannot be shifted out of P (Park) unless the feature is overridden.
Never leave occupants in the vehicle, and always take the keys and lock the doors if you must leave the vehicle idling. Some local laws
prohibit a vehicle from idling unattended. Always remain with the vehicle until it automatically turns off. This could take up to 15 minutes.
I smell a future law suit coming in on this. Just what the OP described, leave pet in idling vehicle and it shuts off, killing the pet. What if it's a child in the back seat, wtf?
Thanks, Ray.  As redwngr pointed out, It’s actually not a stop/start.  It’s an auto stop only - when you let your truck idle it will shut-off automatically after a specific time period.
Thanks all for your replies.  Just have to plan my trips into the store quickly when my sweet little girl (dog) is riding shotgun on our road trips.
Kelly
wtf are you leaving a pet and/or child alone in the vehicle for?
Not me, all gone. Someone will, it's inevitable.
Well, it's not on GM when people do it.  That's on the people leaving the pets/kids in the vehicle.
But you leave a truck running expecting it to stay running. No one told the new buyers, had to find  out from experience.
Regardless of leaving it running or not, people aren't supposed to (and in many places, it's against the law and they can get their pets/kids taken away from them and thrown in jail) leave either their pets or their children in their vehicle unattended.
It's in the owners manual.
If the vehicle is left parked and running with the RKE transmitter
outside the vehicle, it will continue to run for up to half an hour.
inside the vehicle, it will continue to run for up to an hour.
The vehicle could turn off sooner if it is parked on a hill, due to lack of available fuel.
The timer will reset if the vehicle is taken out of P (Park) while it is running.
Some have posted that 'out of park, with the parking brake on' is a work-around.
My truck automatically turns off after 15min.
And yes my dog comes with me to work everyday. I drive from job site to job site as a supervisor. I leave my truck running almost 100% of the time on job sites for specific tasks as well.
Auto shut off is annoying and I wish I could disable it.
  • 9 months later...
Same here, my dog travels to work with me too.  I have a temp alarm that will text me if the cab temp gets too warm for him.  I see no reason why my engine should turn itself off. My previous 6 Duramaxs didnt, and my Ford dosent, so I dont know why this one does. Arg
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
