I recently purchased this 2016 Silverado 1500 LTZ.
It seems really low in the rear.  I was hoping someone might be able to help me determine why.
I don't know what the factory suspension is supposed to look like to determine if it's been altered.
Thanks
Looks like someone lowered it by putting the axle above the leaf instead of below.  Here's mine
Thanks
The leafs are supposed to be above the axle.  Front end may have some kind of drop on it too.
Yup, previous owner lowered it.
Looks like my old truck, except mine was stock height.
[emoji23][emoji23][emoji23][emoji23][emoji1787][emoji1787][emoji1787][emoji1787][emoji1787]
Somebody lowered it. Lol!
Dude, if you knew it didn't look right, you don't buy it!
Sent from my SM-J810F using Tapatalk
Looks great at that ride height, I wouldn't change a thing.
Looks like a 2/4 lowering job. The front either has drop spindles or drop struts with a flip kit in the rear for the 4in rear drop. They also chopped the factory bump stop bracket off the frame to allow for the flip kit. So when it bottoms out, you'll feel it lol.
If you plan to do any towing you will need helper bags in the rear.
  • Thanks 1
Thanks for sharing your knowledge.  I've attached pics from the front end.  It seems to be stock.  What do think?
It's hard to tell in the first pics but the truck has a little squat.
I like the way it looks now but want to get an idea of what I have.  And make sure there's nothing crazy going on.
I don't do any towing or hauling.  Definitely a street only truck too.
The spindle looks factory in those pictures. I'd think they did something with the strut. They sell drop struts and they sell kits that lower the spring perch on the strut body to bring the ride height down.
For reference my truck is has a 1.5/3in drop. Taking these measurements from the passenger side it's 34.5in from the garage floor to the fender on the front and 35.5in in the rear and I have a full tank of fuel. The drivers side is a tad lower because that is where the fuel tank is.
Take some measurements and you'll be able to compare with mine to see how low yours really is.
That's pretty similar to mine. You also have 20's and I'm on 18's so I sit a little closer to the ground based on tire size.
So with that information we know it's about a 1.5/3in drop as well, just performed a different way.
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
