On 9/17/2020 at 7:10 PM, icemanRC said:
I have a 2020 GMC Sierra SLT. One of the factory options is adding the bed view camera for $250. Since mine did not come with this, I wondered if it would be possible to add it? Being that it’s only a $250 factory option, I figured it can’t that difficult to do. Has anyone done this or have any knowledge of this?
Iceman, if you happen to find an answer to adding the bed view camera, please let us know, I too am wanting to attempt to get this installed.
I want an answer to this as well.  I would like to add it to my AT4 to aid in 5th wheel hookup.  Not interested in the mirror.  Just the bed view camera.
-Eli
On 9/20/2020 at 10:34 AM, icemanRC said:
That’s not true, at all. I was looking at two identical trucks. One had the extra bed view camera, one didn’t. The difference in price was $250
I priced up a Sierra SLT on the GMC build and price site and to add the bed camera I had to first have the Driver alert package, convenience package, premium packages to add that $250 camera.
Edited by Greyhound6.2
Yes, but all of that is included in the Premium Plus package, which I have.
On 9/20/2020 at 7:06 AM, icemanRC said:
I would have thought it would be a simple plug and play. I haven’t removed the lamp assembly and looked, but I figured that there’s already a wiring harness there. I couldn’t see it being anything difficult since it’s only a $250 factory option. Cheap options usually mean fast and easy. If it was $1,000 option, I’d believe there was much more to it than just a simple harness plug in.
I guess I will call GMC and see what info I can find out.
Did you ever call or find out anything from the dealer?
  • 2 years later...
Sorry to bring this post back the from grave but interested to know if anyone has done this yet? I just ordered the parts to at least do the live view rear view mirror (DRZ) upgrade. Would be nice to get the bed camera working as well.
Camera review mirror and the bedview camera are separate cameras.
So if you want both you need the assembly with TWO cameras
Yea I ordered the assembly with both cameras Im just not sure where to find the harness or cable that hooks from the bed view camera up to the VCM.
Edited by BrizzlesBowTie23
I purchased the new light with the bed view camera only with wire harness for $175 I plan to install it this week . will update of how it works out
Hate to highjack, but I'm watching closely as well, but I'm looking to add the front camera to a 2023.  I'm thinking whatever gets resolved here just might work for a front camera too?
  • 10 months later...
39 minutes ago, Dennis5.3 said:
thanks but I sold it about a year ago. Only 23,000 miles and had lifter and transmission issues. GM admitted the lifters were bad but said they wouldn’t replace engine until the engine failed. I guess they thought that was quality customer service and thought I would enjoy to continue to stare at a check engine light. This was my first and last GM vehicle.
Edited by icemanRC
  • 8 months later...
@BrizzlesBowTie23 Were you able to figure out and install the rear view camera ?
@djdapper Any luck installing just the bed view camera ?
    Fishboat
    Fishboat
  • Who's Online   5 Members, 0 Anonymous, 605 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
