As the title states - I'm wondering if anyone can tell me whether or not the fenders are interchangeable between the USA built and Mexico built trucks? I have a 2004 USA built and found a perfect color-matched fender, but it's off of a 2004 built in Mexico. I am getting conflicting answers.
Much appreciated!
BK
It's still the same fender so it will work.
I've never seen two different part numbers for front fenders.
Same here, and same with the parts guy I spoke with today. There is one part number for the USA/Canada trucks and a different one for the Mexico ones.
What are the two part numbers? I've also never heard of them being different
GM parts direct shows those two numbers with the same exact picture and parts description. They also list the exact same vehicles for each as to what other vehicles that fender will fit.
No idea why they do that. Mexico just gets their own numbers I guess. The fenders bolt on the same way.
I was looking at that. The list of compatible vehicles is different though and 2004 Silverado 1500 is only on one of them.
I wonder it's a case of years where different production lines only made certain configurations/trims of the different trucks on the GMT-800 platform
I can't imagine why it would be any different either, but I'll find out for sure in a couple days.
The only things I know for sure that they changed over the few years of the 2003-2007 body style trucks was the grille designs and the hood. The later like 2006-2007 hoods look way better than the earlier ones.
Agreed - everything else on the body appears to be identical.
Mexico built and registered vehicles are different than U.S. registered vehicles and as far as the fender it probably wouldn't be galvanized where as the U.S. registered vehicle has galvanized body parts. I know that their vehicles are very cheap and lack safety equipment and other federal vehicle components.
It was a Mexico built, U.S. registered vehicle that I got the fender from. It is identical to the one on my U.S. built truck. I compared the two of them side-by-side and the new one is now mounted on my truck without issue.
Fit won't be the problem for components from a Mexico only vehicle. I know that exhaust systems on Mexican only trucks did not have stainless exhaust just plain raw steel exhaust like our vehicles had in the 1970's.
The parts did vary slightly over the years.  When I replaced the door and fender on my '04 Sierra, I found that fenders and doors from earlier trucks didn't have all the same holes/nuts that later parts had.
    • This video may not be the exact content for the joke thread but its a lot of laughs so here it is, I've only watched a portion of it so far but if anyone is looking for some light hearted good soap box driving action, its here. As a note in the upper left of the screen it shows the number out of 100 to refer back to any particular vehicle for comment !.    https://www.facebook.com/reel/1351928276956715
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
