Has anyone had any luck fitting quad exhaust tips to their T1? I've been researching old threads on the forum and it doesn't look like any one has had any luck, but I didn't see many recent replies so I thought I'd ask. I've seen a bunch of options on Amazon and such but it's hard to tell what would fit since the pipes appear to come into the tips at an angle. I really, really like the square tip model Borla makes but I don't know if they will sell it separately from the catback system. Any ideas out there?
I bought the Borla quad tips and you’re 100% correct about the factory ones being a RPITA to remove! There were some choice words flying around in my garage!
How much were the tips?
Did you have to weld then in? Or can they bolt in somehow?
My apologies, I bought the Borla S-Type cat-back and added the quad black tips to the system. When I received them from Summit, they were already welded on. Had some birthday money to blow, so I went all in. Summit sells just the tips, noticed the Borla ones say “will not fit OEM”.. I see other quad tip brands on their site, perhaps give them a call and see if they’d fit.
Great looking! I think the quad tips give these trucks an awesome look!
I'll 2nd it would be great if you could post some underside pics of how they are attached.
They look great.
Thanks
Jay
  • 3 months later...
  • 5 months later...
On 10/2/2020 at 9:42 AM, lapoolboy said:
Pics from underneath of how they are attached?
Can anyone please tell me the size of the quad exhaust tip that will fit my 2021 Z71 trail boss.
Welcome to the site.
Link was mentioned at top of page. Amazon
Upower 2.5" to 3.5" Dual Exhaust Tip 2 1/2 Inch Inlet 3 1/2 Inch Outlet 9.5" Length Polished Stainless Exhaust Tailpipe Tips 1.2mm Thickness Double Wall Slant Edge for Car Truck
    • I agree.   However, the owner's manual, suggests that a drop over full is just as bad as a drop under. (Read black and white letters only, insert no common sense.)
    • That P0700 and loss of power suggests something significant is amiss to me.   More/other codes may suggest otherwise; I would investigate those prior to spending the money to change fluid on a transmission with a bad torque converter.    The relatively sudden escalation of symptoms to me suggests that something began failing (initial shuddering experienced) and rapidly deteriorated (slipping/loss of power). Fluid condition alone wouldn't cause the sudden escalation of problems - though it might have been the cause of the deterioration up to the point of failure.
    • Stabilitrack operation is in a sense a separate/independent operation from the operation of 'traction control'. Stabilitrack is used to keep the vehicle traveling in the DIRECTION intended, it can brake independent wheels and or adjust throttle to influence the direction the vehicle is moving.   This can be illustrated by a 'fish-tailing' example. At high speeds, if the stabilitrack detects excessive yaw (the vehicle spinning like a top, it has a sensor for this), based on inputs from steering angle it determines that the vehicle is spinning out of control, and begins working to control that unintended spin. By reducing throttle input or braking specific wheels to control or prevent the spin.   The traction control works similarly using the ABS system to slow spinning wheels and thus transfer power to 'other' wheels. The goal being to achieve wheel speeds that are all in agreement with each other, the truck then assumes that since all the wheels speeds are the same no spinning is occurring. For example, launching up a wet boat ramp, there is no excessive yaw present, traction control alone can manage the wheel spin by braking spinning wheels and cutting throttle.   Stabilitrack and traction control from a hardware and software standpoint are basically one in the same, I don't remember specifically in 2004, but you couldn't get a truck with one and not the other. The switch on the dash, could turn off the traction control, but not necessarily the stabilitrack.    A confusing comment about stabilitrack vs. traction control, the same components serve both operations, but marketing could advertise them as two separate features.    The AWD system is another separate system entirely, in addition to the other two, it uses the same wheel speed inputs but can also vary the transfer case clutch application to direct some power to the front axle, working in conjunction with the traction control to bring wheel speeds together.   The power split will never be greater than 50:50, the same as 4-high. It will never direct MORE power to the front axle than the rear.
    • Not based on the new photos I'm seeing.  Car and Driver posted additional photos that shows an auto stop start button left of the steering wheel.
    • Car and Driver is reporting wireless CarPlay WILL remain, and they posted several additional photos, including a left knee shot, but the only hard buttons there are e-brake, auto start stop, tailgate and cargo light.  Also definitely looks like High Country and ZR2 get micro fiber on the center of the console lid and the ZR2 possibly also on the seats.
