I got a 2020 Silverado 1500 back in December and I have about 16000 miles on it now.  I gave it a bath the other day and noticed a crap ton of rock chips in front of the rear tires, right where it flares out behind the rear doors.  My pickup is black and fairly noticable and I was wondering if anyone has a remedy to protect that spot.
Find a local place that does aftermarket paint protection film installs.
A company called Xpel sells a product for this as do others, they sell pre-made kits for vehicles but they are pretty expensive.
Having a place just to small sections will cost you less.
Edited by CamGTP
no real remedy except protective film but that is expensive i also have a month old new black truck and i am not happy with the paint i have chips in mine already the paint chips way to easily i have one in front fender and one in front passenger door and back passenger door that look like crap on black they really show up bad because the primer is white i tried to touch up and buff by hand with micro fiber towel and burned through the paint the paint turned a brown color getting door repainted paint is to thin then i got another in back door tried doctor color chip repair it works ok but you can still see chip may get that door repainted also it is a shame for the money we pay for these trucks that the paint is so shitty
Just a tip for touching up stone chips i saw from a YouTube video. Needle and syringe does wonders for precisely touching up stone chips. Much easier than trying to brush it on. You can pretty much just get the paint in the chip area and not the surrounding area and it lays in real nice.
If someone finds a film that works please post here. The 2 places I checked locally won't do it because the film won't mold correctly with the rough                      " protectant "  in front of the rear wheel and leave noticeable bubbles in the film.
I have a 2020 SLT in the Dark Blue and the paint sucks, picks ups chips and scratches if you look at it wrong. I can say I am glad I made them add the protection package to my contract for free, which they are already regretting I am sure since they had had to repair several chips and scratches. The plastic films are nice when they work but you need to be careful it doesn't void your warranty if you have the protection package. My dealership will give you touchup paint that match a better than the stuff I have tried from autoparts stores. The Needle trick works like a charm.
Thank you for all the replies.  Im gonna save up for the black Luverne side step running boards, and replace the factory mud flaps with weather tech's, the factory ones curve in at the bottom but the weather tech flaps stay square.  I have a friend who works at a body shop who will repair the chips, once I get the stuff in, and hopefully the problem fixed.
how can this void your warranty? I see that often on here, is GM trying not to cover things that have nothing to do with this? or are you just saying for the paint you covered?
Sorry for the confusion, the way I read the appearance guard contract pretty much anything you add to the paint can void the appearance warranty. They want you to use the products they give you and to wax/seal the truck at least twice a year, which I normally do anyway. I dislike the car wash and interior protector they give you so I use my normal Chemical Guys. Shhhh don't tell them lol.
Thanks for clarity - I would argue that outside of where you installed the guard would still be the warrantors responsibility, they might try to bully you a bit, but stand your ground....I believe it would be pretty hard for them to show they are not liable where you have not added any aftermarket...
    • Update for anyone following:    Installed everything as shown in diagram. Opted for 8 AWG from Battery Positive to a 50A resettable inline breaker. 8 AWG is tied into to 2x 12 AWG wires feeding a 6 way fuse bus in parallel (manufacturer’s design of what I purchased).    4 of the 6 fuses available for circuits are tied to terminal 30 of each relay. I tied a jumper from one of my spare circuits off the bus to terminal 86 of each relay. The trigger, terminal 85, was pulled from my interior by way of T-Taps from the X61A-X5 pins 10, 11, 17 and 23. This was the hardest part of the job. Even with the X61A unbolted and the X5 removed - there was VERY little wiggle room.  I added back up lights that I want to come on with my cargo lamp - but when I would check continuity between S48A-X1 pin 18 to its respective landing point on the X61A-X5 it triggers the factory relay… Instead I opted for a add-a-fuse on the passenger interior fuse panel (fuse location 10 - cargo lamp) and ran it through the boot on the driver side to my load. Did this to avoid introducing any electrical gremlins.   Note: Please check for continuity between the S48A-X1 and the X61A-X5. In my case wire colours were not the same as other’s who have posted. To do a continuity check you need a Multimeter. Completely disassemble the S48A-X1 and remove the brown face plate off the X61A-X5 by way of a flat head screwdriver - this was the only way I could get any results.   The outputs, terminal 87 of the relays, were fed into a junction box and landed at Individual studs and were labelled Aux 1-4.    At this point, all you need to do is run wire to your loads and bring them to ground. I created a negative bus in the engine bay, all my negatives land here.    For anyone having issues with all of your new aux switch lights coming on with the press of one - I noticed this only to be an issue when the battery wasn’t hooked up to my relays? No idea why, but it was quickly corrected by having my system buttoned up and functional.
    • Well I ordered the Autel ts508, and it won't work on my truck I tried all the 2023 and everything it just says vehicle not supported lol   I'm able to send this unit back, so I'm going to do that, then I'll just stop into a some tire shops and if none of them are able to do it, I guess ill have to spend a bunch of money to get a good scanner..... Thanks GM lol
    • Don't need the air tube but that's how everyone sells them. Most places won't remove that one piece and sell it alone. No money to be made. Hoping someone swapped theirs out for a CAI and no longer wants it. Not asking anyone to give it away. Offering to buy it but I don't need the tube. It's held on by a hex head screw and nut. Been all over eBay.
    • Wait, you guys are changing your oil???
    • If you need that mount looking piece.  You need the air tube.       Cheapest one I see on eBay - 2007-2014 GM Silverado 1500 Air Cleaner Outlet Duct Assembly 5.3L OEM 15901934 | eBay     Same price but free shipping - 2009-2014 CADILLAC ESCALADE 6.2L AIR CLEANER OUTLET DUCT ASSEMBLY 15901934 OEM | eBay
