What to do on a fall day, buy a new truck of course! 2021 Sierra SLT Diesel..Stumbled across it randomly as inventory has been garbage thanks to Covid. Got a pretty decent deal, I couldn’t pass it up. This is my first Diesel so this will be a learned experience to say the least!
I’ll surely miss my 17’
Edited by Crazypontiac03
12 minutes ago, steve8 said:
Congrats/looking good.
Whats a "decent deal"?
Around here right now 9K off list plus 1k Costco rebate. Plus gave me 33K for my 17’ CC LT. which is pretty good Considering I bought the 17’ two and half years ago for 37k @17K.
It’s a lease as GM financial  wanted way to much in interest, plus it’s my first Diesel which was the main reason in case I dislike it for whatever reason.
Very nice truck!  I recently found a similar truck that caused me to get out the calculator and do some serious arithmetic!   In the end my ''15 c/w no payments won the day.  I never considered leasing but this is an interesting option worth investigating next time! Congratulations on your new truck!
Yea, I went back and forth with lease vs. buy at the end of the day based on the current economic times and my personal stance on trying a diesel. I see no difference in Buy vs. lease unless your current truck is paid in full. Either way a Bank still holds the title until the end of the term. If this truck is worth less than 34k in 39 months, I give it back to GM or if it’s a POS. If it’s worth more than 34k and i’m still in love with it I can buy it outright. Plus I live in IL so they tax us on our trade also, anything worth over 10k you pay the taxes on both the trade and the new unit it’s 1k for every 10k. I was looking at about 5k in taxes alone between the two trucks. Under a lease you only pay the taxes for your current lease term. I personally believe with the ever rising costs of vehicles if you don’t drive 20-30k a year leasing will be the new norm. Thus far in 2020 54% of vehicle transactions have been leased. Just something to think about..
I leased mine a well, since I generally use it as a tow vehicle.  I've had it 18 months and just turned 6k miles.  Guess I have a few miles to make up......this one will most-likely be going back, as the jingle jingle front axle will never be fixed correctly.
I also leased as back in July the money factor calculated to 1.57% interest rate and the residual value is 61%.  Also got $3k dealer discount, $1,500 lease credit plus GM educator discount which I recall was $2,995.  It's a 39mo/12k miles per year lease and up front fees were SC tax ($500) plus first month payment.  Over the years I've leased and purchased.  I like a new vehicle every 3 years or so and leasing at these rates is hard to beat.
Congrats. Love the color!  I would love to lease but I’m already at 17k and still have two months to make it a year with my truck.
1 hour ago, loopbacksean said:
Nice truck, but why did you go from standard bed to short bed?
Only reason was it’s what they had on the lot that was a Dmax. It’s also has the Mutipro tailgate so that helps with the longer home improvement items.
22 minutes ago, redwngr said:
Congrats on the new ride!
Will the garage door close?
Yes the old truck was able to fit. I had about 3”. ?
    ChristopherDobson
    ChristopherDobson
  • Who's Online   4 Members, 0 Anonymous, 1,243 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
