1 hour ago, Greg slater said:
rear window leak
Just "rear window leak"? Be more specific with details.
10 minutes ago, CamGTP said:
Must have thought this was google or something.
Yep, just a week post. Does he have a leak? Inquiring about a leak? Where's it leaking if so. What truck?
Slider? Non slider?
REAR WINDOW LEAKING ON DRIVER SIDE.HAD REPAIRED TWICE.STILL LEAKS DRIPPING FROM TOP INSIDE MOLDING
So you just had the TSB fix that reseals the rear window?  Or did you have the rear spoiler replaced / fasteners re-torqued / re-sealed?
Have you looked at the rear window to see if the frame is cracked?
It could be that they are sealing the rear window and the leak is actually coming from the spoiler down to the window.
This last time they resealed the spoiler. They  had to order new nuts and special sealer.
Mine leaked on the passenger side, they resealed the spoiler and and all was good for a little over a year. This summer it started leaking on the drivers side, they replaced the window this time. Time will tell if it is the final fix.
Might be the window frame is cracked.
