so will be in the process of adding electric brakes to the boat trailer and a complete light/wire re-do. I really want to get away from the frame mounted brake/light ground wire that you so often see, and run both ground and power all the way to the junction block! My problem I'm running into is running out of room in my junction box! designing it out, I'm coming up with 20 ground wires for all the lights and brakes! no way you will fit that on the one ground stud in your common 7 way junction blocks. I found a 10 way junction block, that will help, but I'm still looking at 11 positive wires for the marker/running lights.
just looking for ideas and what you guys have done.
trailer has; 4 brake plates, 2 S/T/T, 2 back up 1 center id bar, 10 side marker lights.  Confused Hanna Barbera GIF by Warner Archive
Using the frame of the trailer for grounding purposes is not an issue as "it works" and is why the manufacturers all do it. There's really zero reason to home-run all of the grounds back to a central point since the metal of the trailer already does that.
The REAL problem with trailer grounding is that the ground wire from the harness that attached to the trailer frame always seems to get damaged and then you're relying on grounding of the wiring through the hitch back to the two vehicle's frame. Focus your efforts on ensuring that the main ground to the frame stays protected and attached and you should have no issues. You can always coat the attachments with grease or even have the underside of the trailer sprayed with bedliner to protect everything (this is very commonly done by owners of snowmobile trailers).
OP,  before we get ahead of ourselves here, please explain how in the world you expect electric brakes to work more than once on a boat trailer that is used to launch a boat. There is a reason that boat trailers come equipped with hydraulic surge brakes, water and electricity don't mix. There are electric over hydraulic systems for boat trailers where the hydraulic brakes are activated by an electric controller, but said controller still needs to be mounted somewhere on the tongue of the trailer where it won't ever get wet.
Electric brakes have become a normal or standard “economy” brake in the marine industry, all you are doing is energizing a magnet, use the waterproof connectors and it’s no different than backing the trailer lights in the water.
Eoh disk is by far the best route! I have a boat trailer that has that setup and it’s awesome! Just to retro the boat trailer I’m working on is not worth the investment for a boat that I don’t plan to keep forever, I can swap from surge to electric for about $500 to convert to eoh is about $2500. it’s a second boat and not primary use for us but at 11k working brakes are a must in my opinion.
Surge brakes well they just suck... I can’t stand the start and stop clunk, hate the feeling of the trailer trying to pass the truck before the trailer starts to brake, and not having trailer brake control at my hand drives me up the wall.
Well, I learned something, but still wouldn't electric over hydraulic still be your easiest and cheapest option?  As far as the trailer lights, I always unplugged them in the parking lot prior to launching as a leaking light seal that allowed water in the housing would pop the bulb when the cold water hit the heated bulb from the brake lights.
Edited by garagerog
No, eoh is pricey, the actuator alone is 600-800 depending what one you choose, and more a pain in the ass to run bend and flare lines... if I was planning on keeping this boat forever yes I would do it but I don’t anticipate much more than 3 to 5 years... on my smaller boats over the years yes, I also unplugged the lights, but as the boats got heavier when you unplug your lights you lose your brakes, not worth the truck going forward a swim... I keep them plugged in. My bots are in the 10-14k range
  • 3 months later...
Since when have electric brakes become commonplace or the standard “economy choice” for boat trailers? Surge or EOH; you’re out to lunch with straight electric.
    • Update for anyone following:    Installed everything as shown in diagram. Opted for 8 AWG from Battery Positive to a 50A resettable inline breaker. 8 AWG is tied into to 2x 12 AWG wires feeding a 6 way fuse bus in parallel (manufacturer’s design of what I purchased).    4 of the 6 fuses available for circuits are tied to terminal 30 of each relay. I tied a jumper from one of my spare circuits off the bus to terminal 86 of each relay. The trigger, terminal 85, was pulled from my interior by way of T-Taps from the X61A-X5 pins 10, 11, 17 and 23. This was the hardest part of the job. Even with the X61A unbolted and the X5 removed - there was VERY little wiggle room.  I added back up lights that I want to come on with my cargo lamp - but when I would check continuity between S48A-X1 pin 18 to its respective landing point on the X61A-X5 it triggers the factory relay… Instead I opted for a add-a-fuse on the passenger interior fuse panel (fuse location 10 - cargo lamp) and ran it through the boot on the driver side to my load. Did this to avoid introducing any electrical gremlins.   Note: Please check for continuity between the S48A-X1 and the X61A-X5. In my case wire colours were not the same as other’s who have posted. To do a continuity check you need a Multimeter. Completely disassemble the S48A-X1 and remove the brown face plate off the X61A-X5 by way of a flat head screwdriver - this was the only way I could get any results.   The outputs, terminal 87 of the relays, were fed into a junction box and landed at Individual studs and were labelled Aux 1-4.    At this point, all you need to do is run wire to your loads and bring them to ground. I created a negative bus in the engine bay, all my negatives land here.    For anyone having issues with all of your new aux switch lights coming on with the press of one - I noticed this only to be an issue when the battery wasn’t hooked up to my relays? No idea why, but it was quickly corrected by having my system buttoned up and functional.
    • Well I ordered the Autel ts508, and it won't work on my truck I tried all the 2023 and everything it just says vehicle not supported lol   I'm able to send this unit back, so I'm going to do that, then I'll just stop into a some tire shops and if none of them are able to do it, I guess ill have to spend a bunch of money to get a good scanner..... Thanks GM lol
    • Don't need the air tube but that's how everyone sells them. Most places won't remove that one piece and sell it alone. No money to be made. Hoping someone swapped theirs out for a CAI and no longer wants it. Not asking anyone to give it away. Offering to buy it but I don't need the tube. It's held on by a hex head screw and nut. Been all over eBay.
    • Wait, you guys are changing your oil???
    • If you need that mount looking piece.  You need the air tube.       Cheapest one I see on eBay - 2007-2014 GM Silverado 1500 Air Cleaner Outlet Duct Assembly 5.3L OEM 15901934 | eBay     Same price but free shipping - 2009-2014 CADILLAC ESCALADE 6.2L AIR CLEANER OUTLET DUCT ASSEMBLY 15901934 OEM | eBay
