When going over speed bumps especially, but really any bump, the front bouncing like crazy. It feels like I'm in my granddad's old 1973 Cadillac Eldorado. Not what I was expecting when I bought my truck. This is my 5th GMC truck since 1994, far more bounce than ever experienced. Is there a simple fix like installing aftermarket shocks? This thing drives awesome going down the highway or streets, I love the ride, don't want to change it. Just wondering if and what kind of shocks would give me what I'm looking for???
I went to Bilstein shock and struts and it made a huge difference. A tiny bit stiffer but I like them a lot.  Rides great now.
I haven't had to have the fronts switched out.  I have the struts, but haven't had time to get it to a shop.  I too swapped to the Bilstein 5100's.  The rears are in and it is night and day difference.  Drives like a charm now.
I'm considering the Blistens after seeing such great reviews. I like the way my truck rides except for the bouncy rear end over bigger bumps and thresholds. How much do these run? And is it a labor intensive job to DIY? I've never messed with shocks before.
Is it worth it to do all four? Or should just the rears be plenty?
I want to do the front since that is still bouncy, but the rears make a huge improvement.  It takes 15-20 minutes to swap out yourself.  It's DIY, and you don't need a jack.  Just pull the old ones one side at a time and replace with the new ones.  It's $94 per shock from shockwarehouse.com and free shipping
I had 5100s on my 2009 Silverado and they were night and day difference.  I will want to put them on my 2020 soon.
The bouncing is pretty annoying.  If it makes that much difference in the rear I might pull the trigger on those.
I'll likely go Bilstiens in the back coupled with a Deaver AAL - Cognito has one that you can adjust lift on (I want to drop the lift from my AT4).  I had Kings front/Deaver&bilstien rear on the last truck and loved the ride.
I want to get the Bilstein 5100's in the rear and 6112's in the front of my Trail Boss and keep the same ride height (with rake). But I haven't heard of anyone doing that before. Bilstein's website shows that the 6112 is available for a 2020 LT Trail Boss for the front. I just don't want to have to deal with replacing UCAs and I really like the height the truck is at now.
My truck has the factory Rancho's (High Country with Z71). Will switching to Bilstein help when towing?
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
