Any thoughts on replacing the OEM basic stereo for something with Apple CarPlay?
I've got a 2016 GMC 3500 base with the basic tiny little radio.
I'd like a bigger screen, compatibility with the OEM backup camera (even though that is awful), and a trim ring that looks as stock as possible.
Replace with a 17 stereo? Apple car play enabled
Interesting idea. Would that be plug and play? I imagine I'd need all new trim pieces and wiring harness and have to splice it all together?
I used 2016+ radio/HMI on my 2015.5 to add Android Auto/Carplay. There is a huge thread on how to do it, parts required, and companies that can do the programming. I believe that thread is on the K2 1500 forum.
I swapped out the radio in my 15 high country with the bose. You need a radio capable of rr maestro. You need the alpine amp adapter or do the amp bypass like i did with the harness and aftermarket amps. U also need the gm3 harness. Night and day difference. I got aa, mirrorlink wireless and rear entertainment. Total investment around 900.
Wow. Sounds awesome. And complicated. I'm looking for more of a plug and play kind of thing. Apple CarPlay capable radio, with a wiring harness that's plugs into the stock harness.
If you dont have a bose sound system any shop can install a aftermarket radio. U need the rr maestro to keep window, door lock functions and other functions.
No Bose system. Base model stereo here.
What do the Window and door functions have to do with the radio?
In ur radio do u change any settings. Door locks, collision detection. My stock radio controlled the functions of the truck
Ah yes. You're right. Hm.
Then you will need the rr maestro and gm3 harness. I do not regret the upgrade. To go to aa from what i had was around 700. Now i have a lot more features and ob11 hookup through radio. I did a pioneer avic8400 radio, kept the stock speakers. Re used my stock radio bezel or u can go with aftermarket bezel. You also need the amp bypass harness if the speaker leads are behind the back seat
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
