I have a 2020 Silverado 1500 LT Z71. I have always thought it was weird that I could not see the climate information unless I changed something and that little pop-up appeared.
Although I noticed on some reviews and models that some have a dedicated climate button in the infotainment.
Is this a fault? I'm not sure why having a climate button in the infotainment would be locked to certain packages and can't find any documentation around it.
1 hour ago, Vigilante375 said:
I just glance at the buttons to see what's set..... there is also climate app or whatever it's called. Just like how the audio and phone thing is on the infotainment.
Yeah that's the button or "app" that I'm referring to. My truck does not have that in the infotainment.
What trim level is your truck? Any packages?
I'm not really sure what you're talking about but mine is the same trim as your's.  LT Z71.  Not certain of the other packages but I have the app and this is a picture I found on the web as I'm not in my truck this week.
I don't see why this would be linked to certain vehicle trims.  You can find it by looking for the person in a seat on the infotainment.20190417_173130.thumb.jpg.76beb74578b4fa9ebb9ba1a04a8c85f9.jpg.8903bc0eaad3eb563e0e4da38aaa34d1.jpg
Other than that, you can easily look at the climate controls on the dash in between the temp control.  Thats where I always look. I never really use the touch screen for the climate.
Edited by Vigilante375
That's what I'm talking about. My truck does not have that button in the infotainment. It's just missing.
Is yours 2019 or 2020?
Any packages?
19 hours ago, shanemoon said:
Bump
Does you screen have 2 or 3 little dots at the bottom - centre?
If it does, try swiping the screen left/right to show the other page(s).
I believe if you want that feature you need to have the IOS and up Radio to get that feature...If you have Conv package 2 you'll have it I believe..Kind of a useless feature if you ask me...
Per the manual, only dual automatic climate control equipped vehicles have the climate control status display on the infotainment screen. Standard climate control equipped vehicles do not.
Yeah. I do have dual, automatic climate. But no climate control button in the infotainment. That's why it seems weird, because when it's in auto, I have no idea what it's doing. Seems like a weird bug...I guess I'll have to take it to the dealer and figure it out.
My thoughts exactly. You can look at the HVAC controls and see everything that is on that screen.
I wish you could rearrange the lower "fixed" icons.
Edited by mjonesjr84
Any packages?
Sorry for taking so long but I looked at the sticker for my 2019 LT Z71.  It has these packages; All Star Edition, Convenience II, Z71 and protection, trailer brake and 5.3 (since that was optioned).
As it was mentioned, this feature is kinda pointless when it shows you the exact same thing the HVAC controls show.  It doesn't even have the heated or A/C seats on there.  I've only looked at it and played around with it a couple of times.
If you really want it and think you're truck should have it, then take it to the dealer and they should be able to reprogram it for you.  If you're truck is supposed to have it, then they will do it for free.
Do you have HD radio? There's a few trims that don't have that, or the climate control. I'm not sure which level they are, but it sounds like you don't have that level of radio.
If you hold down any icon, a pop up comes on and you can swipe the apps up to delete. I wouldn’t think it would let you delete that icon, but maybe somehow it got deleted. If that’s the case, you could try doing a radio reset in the settings app and see if it comes back
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
