38 minutes ago, diyer2 said:
 I have a 12 Sierra 5.3 6 speed 3.42's. I live in the mountains of Colorado. I purchased this truck knowing the heaviest thing I would tow regularly was my boat. It weighs about 3500-4000 lbs. The truck does OK with this except pulling grades. You have to down shift to kep up your speed. This causes higher RPM's. Sometimes running it harder than I like so I just find a gear and slow down. The 6 speed trans is the killer.
I have towed heavier 8-9 K pounds and it works hard in the mountains.
I agree with evad and dieselfan1.
If I was towing heavier I would definaely get a 2500 with the big gasser at minimum. More gears in the trans the better.
Lol, i used to tow that up grades with an fj60 landcruiser with 120hp on a good day. 355hp having a tough time with 4k lbs.
1st world problems to the max
Let me clarify. Didn't have problems. Just in some cases towing grades I don't run the truck hard so I slow down into a lower gear and lower RPM's. If your not in a hurry no big deal. I'm not in a hurry. It would be nice to maintain speed limit though. I towed a lot with a 93 Silvy 1500 5.7 373 gears 4 speed. This truck is a big improvement.
Fun facts.
1.) 5.3 Ecotec makes 350 lb/ft or more between 3100 and 5200 rpm peaking at 4100 rpm
2.) Top gears in automatic transmissions are OVERDRIVES. Not really heavy tow gearing.
To get this motor pulling at it's peak torque and on stock tire sizes and a wish for 65 mph speeds would require running in 4th gear with a 4.56 diff....4,100 rpm. You would have 383 * (4.88 * 1.15) = 2,149 pounds feet axle torque.
With a 3.42 and pulling 3rd gear at 65 mph 383 * (3.42 * 1.51) = 2,004 pounds feet axle torque.
But you guys want high gear? 383 * ( 3.42 * 0.67) = 878 pounds feet torque.
What your asking for is diesel like performance from a gas motor or torque limited turbo gas motor perhaps.
You can stuff 10 extra gears in that transmission  and it will always be about multiplying what is available. If you want to tow at 1500 rpm where there is less torque then you have to multiply it more...lower gears....slower speeds.
2014 Silverado Delivers Power, Efficiency and Value
You guys bought motors that peak torque at 4100 rpm and then don't want to spin it to use it. What is a fella to do? ?
47 minutes ago, Grumpy Bear said:
Fun facts.
I'm not afraid to spin mine. The 5.3 is a stout platform. Made to rev if you ask me.
I ran in 3rd and 4th gear last trip on the way home into a 20-25 headwind. 3500-4500 rpm for hours to maintain 60-62 mph.
The gas mileage is the killer here. 6-7mpg - 150 miles to a tank max.
Another thing I noticed is after running 4 grand for a while it warms up to around 230° then the thermostat opens and brings it down to 210°. Rinse and repeat.
Tranny runs at 190°-195° steady under these conditions.
If you're not afraid to run at that rpm's the truck will tow it just fine , just requires a lot of gas.
15 hours ago, JimCost2014 said:
If you are talking about the yellow sheet, that is a scale ticket. In this case a private entity, but similar as what you would get from a weigh station on the highway.
The numbers are showing the weight at different spots on the truck, and a grand total.
OK!  Thank-you.  I thought it was the door sticker.
13 hours ago, CamGTP said:
The tow rating sticker does not exist on the K2XX trucks, that is only on the 2019+ model year trucks.
The only thing you will find on your 2016 is the VIN sticker that shows the build date and gross vehicle weight without the trailer.
I stole this from google but it looks like this.
These are the only stickers I found on my door(s) and glove box.  Checked all four doors, the jambs front and back.
Ken,
What trailers are you looking at?
I'm looking at this one for next year.
2021 Wildwood 24RLXL. I was quoted $17,980 plus tax and license.
Empty around 5000 lbs.
Sloped front for less wind resistance. Nice setup for the price. These tow nice a freind has a similar setup(Salem) and tows with a 2017 Sierra crew cab 5.3 6spd 3.42 and never said he has trouble although he only goes up north with it (140 miles fairly flat) once a month.
I'm fairly confident that this trailer will tow easier than my current trailer with the flat front.d549f5deb9ce72712a4892286372a9f9.jpg
Sent from my Pixel 3 using Tapatalk
Haven't started looking at any RV's at this point.
Plan to stick with a local dealer for simplicity of warranty and repair.
Local is great as long as you are in a small town. If you are in a large metro area and bring it for warranty work plan on not getting it back for a month or two. It's a big joke, the dealers take your money and then when you need something fixed you are on the back burner. My friend just bought a new Arctic Wolf fifth wheel. The 12 volt refrigerator quit first trip. He brought it back to dealer and they had to order a new one. They had it for 7 weeks. Lame.
The RV world has exploded since coronavirus. The dealers can't keep up with the warranty work.
Out of curiosity, wouldn't it have been smarter to let the dealership see and diagnose the problem.
Order the new frig while keeping the old frig, regardless if working while you wait for new, then bring back for swap out once in.
At least you could still go camping.  May have to rough it with a cooler full of ice.
Just a thought.  Seven weeks is a long time.
Go over to any RV forum and there are horror stories galore.
    • I have a 2015 Silverado and sometimes I can not get in to the truck. I use the key to unlock the driver door. Something is locking the truck when I unlock it, last night I left the truck open and this morning it was locked with the mirrors folded in. This happens while driving so it is now a safety issue. I reach down for the folding button and they open, then they close again.  Any advice, thank you,   Ed
    • Did you ever find a resolution to this? my 2019 Silverado 1500 is showing the exact same headlights issues with the exact same symptoms.  would help a ton if anyone has any advice on this or better yet a known solution..
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
