Hello,
          I have been having issues with my push button start inside the vehicle. It has gotten me stuck 5 times now. After the 4 time my wife took it to the dealership and they said it was 2 bad remotes and that was on Wednesday.  Sunday I went to run some errands and stopped at a gas station and got back into the truck and hit the start button and nothing again. Called roadside service and had them send a tow truck to come get it. The tow truck driver had to drag my truck up on the flat bed as the steering column was locked and the parking brake was also on. I also previously brought this truck in for a hard shift problem and they drove it for 10-15 miles and said they could not reproduce customer complaint.  This truck is sparingly used as I have another vehicle to drive during the week for work. I use this truck for towing our camper, and for my everyday driving when not working. It has about 8700 miles on it. I have always been a Chevy Owner, but got away from them for a couple of years and got a Nissan. When we bought the camper had to have something bigger so I went back to Chevrolet. It has been an udder disappointment! I am hoping they can fix it for good or I will get rid of it.  Has anyone else have this issue with push button start?
There have been numerous posts about the same type of issues. One thing I keyed on was an issue with the bolts in the underhood fuse box not fully tightened. There is a TSB for the issue. It is for 2019 but I have seen posts about the issues on later models. Do a search.
May not fix your issue but it is easy to check.
  • 4 weeks later...
On 11/8/2020 at 5:11 PM, Scott Courtney said:
Hello,
Yes.  Had this problem and the problem where the starter cranks and won't stop (never fires up).   Dealer can't reproduce it and it doesn't throw a check engine light so they throw their hands in the air.. stooges.
My brother suggested bad relay contacts on the starter so that'll be my next review.  DAMN I hate these push button starts.  Where do i put the key in?
  • 3 months later...
I have a 2021 and having the exact same issues. I’ve experienced this 4 times. 1st two times the truck eventually started, but I took it to the dealership anyway and let them know what was going on. I was told, we can’t recreate the issue and was sent in my way. On the 3rd time(the truck stopped on the hwy) I ended up burning out the starter trying to get off the median!!!! Nothing worked and I tried so long the truck died. I ended up having the truck towed to the dealership. The dealership said it was a starter and bad btry fuse. Here it is 1 month later and I’m having the issue again this time at work!! After the 4th attempt it finally turned over.I have about 18,500 miles and I’m not feeling confident about chevy
  • 1 year later...
My engine start button’s bezel around it doesn’t sit right, it’s wobbly if that makes sense. Not sure if it’s always been like that. Anyone know if the whole thing pops off and I can try re-seating it?
You can buy a whole new push button assembly for i think $40?
Do you happen to know the part number or what to search for?
I tried to go back and find where i saw it with no luck. If i come across it again ill just send you the link in pm.
  • 1 month later...
As a diagnostic, I would try using the fob start if the button start doesn't work.
Both send a signal to the computers, and the computers manage the start routine.  This also means it is not necessary to hold the button until it starts.  (same is true for newer GM's with a key. 'Bump and release' the key to the start position and computers take over and do the rest.
I don't know if it is necessary to be out of the truck when using the fob.
As a side note, it is not necessary to hold the button until it starts.
If fob and button both don't initiate a start, that is extra info for the repair diagnostics.
If the truck has the phone app active, the start request from the app cold also be tried.
  • Thanks 1
So you're basically saying if the key fob will start the truck then the ecm is not at fault?
I found two TSBs that may be related to this issue, but wanted to hear from the two owners of how their problem was resolved.
Though I haven't experienced the issue myself, that is awesome information!
I know that if I was "in the moment" that I might not have considered the other two options, but hopefully this helps somebody else out and would be great information to provide a technician when needed.
  • 1 year later...
If this happens, all you have to do is disconnect the battery and you'll be able to start the vehicle. I've had this issue twice in less than two weeks. I'm trying to find a fix.
The first time thus happened I did both. It still did not react to me stepping on the pedal and pushing the button. There is something just "not there", and you notice it as soon as you open the door. Mine said "programming fob". The fob was in my hand and nothing was in the cup holder.
  • 1 month later...
So my 2020 2500 6.6 gas, is having the same issue the push button not working just a click in the column. I replaced the battery and battery distribution bar, and the alternator is good. Took it to Chevy house they couldn't figure it out either. They just gave me a BS story of they get no codes and then came back and said they got an replace the starter code so bought a starter but the remote starts it every time even on the first cold start of the morning I'm at a loss can someone please tell me what's the problem and best fix please and thank you
    Sothpaw27
    Sothpaw27
  • Who's Online   6 Members, 0 Anonymous, 563 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
