Hello,
          I have been having issues with my push button start inside the vehicle. It has gotten me stuck 5 times now. After the 4 time my wife took it to the dealership and they said it was 2 bad remotes and that was on Wednesday.  Sunday I went to run some errands and stopped at a gas station and got back into the truck and hit the start button and nothing again. Called roadside service and had them send a tow truck to come get it. The tow truck driver had to drag my truck up on the flat bed as the steering column was locked and the parking brake was also on. I also previously brought this truck in for a hard shift problem and they drove it for 10-15 miles and said they could not reproduce customer complaint.  This truck is sparingly used as I have another vehicle to drive during the week for work. I use this truck for towing our camper, and for my everyday driving when not working. It has about 8700 miles on it. I have always been a Chevy Owner, but got away from them for a couple of years and got a Nissan. When we bought the camper had to have something bigger so I went back to Chevrolet. It has been an udder disappointment! I am hoping they can fix it for good or I will get rid of it.  Has anyone else have this issue with push button start?
There have been numerous posts about the same type of issues. One thing I keyed on was an issue with the bolts in the underhood fuse box not fully tightened. There is a TSB for the issue. It is for 2019 but I have seen posts about the issues on later models. Do a search.
May not fix your issue but it is easy to check.
On 11/8/2020 at 5:11 PM, Scott Courtney said:
Hello,
Yes.  Had this problem and the problem where the starter cranks and won't stop (never fires up).   Dealer can't reproduce it and it doesn't throw a check engine light so they throw their hands in the air.. stooges.
My brother suggested bad relay contacts on the starter so that'll be my next review.  DAMN I hate these push button starts.  Where do i put the key in?
  • 3 months later...
I have a 2021 and having the exact same issues. I’ve experienced this 4 times. 1st two times the truck eventually started, but I took it to the dealership anyway and let them know what was going on. I was told, we can’t recreate the issue and was sent in my way. On the 3rd time(the truck stopped on the hwy) I ended up burning out the starter trying to get off the median!!!! Nothing worked and I tried so long the truck died. I ended up having the truck towed to the dealership. The dealership said it was a starter and bad btry fuse. Here it is 1 month later and I’m having the issue again this time at work!! After the 4th attempt it finally turned over.I have about 18,500 miles and I’m not feeling confident about chevy
My engine start button’s bezel around it doesn’t sit right, it’s wobbly if that makes sense. Not sure if it’s always been like that. Anyone know if the whole thing pops off and I can try re-seating it?
You can buy a whole new push button assembly for i think $40?
Do you happen to know the part number or what to search for?
I tried to go back and find where i saw it with no luck. If i come across it again ill just send you the link in pm.
As a diagnostic, I would try using the fob start if the button start doesn't work.
Both send a signal to the computers, and the computers manage the start routine.  This also means it is not necessary to hold the button until it starts.  (same is true for newer GM's with a key. 'Bump and release' the key to the start position and computers take over and do the rest.
I don't know if it is necessary to be out of the truck when using the fob.
As a side note, it is not necessary to hold the button until it starts.
If fob and button both don't initiate a start, that is extra info for the repair diagnostics.
If the truck has the phone app active, the start request from the app cold also be tried.
So you're basically saying if the key fob will start the truck then the ecm is not at fault?
I found two TSBs that may be related to this issue, but wanted to hear from the two owners of how their problem was resolved.
Though I haven't experienced the issue myself, that is awesome information!
I know that if I was "in the moment" that I might not have considered the other two options, but hopefully this helps somebody else out and would be great information to provide a technician when needed.
If this happens, all you have to do is disconnect the battery and you'll be able to start the vehicle. I've had this issue twice in less than two weeks. I'm trying to find a fix.
The first time thus happened I did both. It still did not react to me stepping on the pedal and pushing the button. There is something just "not there", and you notice it as soon as you open the door. Mine said "programming fob". The fob was in my hand and nothing was in the cup holder.
So my 2020 2500 6.6 gas, is having the same issue the push button not working just a click in the column. I replaced the battery and battery distribution bar, and the alternator is good. Took it to Chevy house they couldn't figure it out either. They just gave me a BS story of they get no codes and then came back and said they got an replace the starter code so bought a starter but the remote starts it every time even on the first cold start of the morning I'm at a loss can someone please tell me what's the problem and best fix please and thank you
    TopBo
    TopBo
  • Who's Online   2 Members, 0 Anonymous, 798 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
