"Ask the GM Technician" is probably not the correct forum for this. GM techs repair vehicles to factory standards. At least up here in the Northeast, zero performance modifications are ever performed.
Hover over the "Forums" tab at the top of your window, and find the appropriate thread based on what year / model you have. I believe there's a dedicated performance mods section, too.
Edited by Jsdirt
1 hour ago, crabcake said:
Looking for information on plug in performance booster such as the Sprint booster V3 power converter?
You'd be better off throwing money at a wall.  All that is doing is pretty much the same thing as a pedal commander.  Just tricks the computer input on how far the pedal is being pushed.  It offers no actual performance gains whatsoever.
Set aside $600-800 for a good 93 octane dyno tune or Blackbear performance tune instead.
Ahh, it's one of those eBay tuners. ? No wonder I had never heard of it.
What year and engine would help a little.
I'll take "whats a bot?" for $400 Alex. (RIP)
  • Haha 1
Cheaper to simply put a piece of wood on the gas pedal.  It will do the same thing until your muscle memory learns it.  You could then remove it and think the vehicle is a real dog now.
I just tuned my 2010 Tahoe 5.3 with a diablo sport tuner plug in thing I borrowed from a coworker
Turned off afm and torque management and tuned it I guess? 87 octane tune is what I selected.
Drives much better in the mid range I like it
    • Pretty much zero rust on the truck, the frame is super clean. Non-snowy area of California for its whole life. They didn't mention JB weld specifically, just a silicone style seal.
    • Needs a manifold gauge hooked up and the pressures read.   If you don't have one, time to take it to a shop and have it diagnosed.
    • How rusty is the truck?     The transfer cases on these are an aluminum case.  If its anything like the rear diffs on the 2015-2022 Chevy Trax, those will corrode bad to the point it will push fluid through the housing via corrosion porosity or a crack from age/stress.    We have seen folks over tighten the drain and fill plugs on these transfer cases and crack them that way as well.    So I'd say its a 50/50 shot on re-sealing the case.  If all of the surfaces are good and its not badly corroded, they probably can re-seal it.  GM uses RTV to seal the case halves.   If they mention JB Weld, the issue is the case.  Be it a crack or corrosion.  JB Weld "might" hold if they clean EVERYTHING very well and drain the fluid out of the case and clean the crack and then seal it.
    • A while back, my truck (2018 GMC Sierra 1500 5.3) went in for an o2 sensor and routine service. The tech identified that my rear output seal on my transfer case was leaking, and recommended I have them replace it. At the time I didn't think anything of it, and had them do the repair. Less than a month later, I noticed that the recently repaired seal was leaking again. I called the shop that did the repair and they warrantied the repair and replaced the same seal again. A few months later, I noticed that once again the same seal leak had come back. It wasn't a great time to bring it in and I ended up just living with it for 6 months or so, noticing small (smaller than a baseball) size oil stains below the truck when it would sit for a while, as well as oil spray on the frame (to the point where it actually took the underbody coating off in that one spot). Finally got around to brining it in again, but this time I took it to a dealership service center since I am in a different part of the state for school. They identified the same output seal leaks and recommended they replace them. They also said there was no scoring on the inside of the transfer case, so it didn't need to be replaced. They chalked up the original repair failures to non oem seals and a job that wasn't done correctly. Now they called and said the seals are holding after driving/sitting for a while, but they found a very small leak in the middle, that they recommended they seal with some kind of silicone/jb weld (not sure what they are using). I haven't picked up the truck yet, but I have been reluctant about this whole repair process because I feel like they are just fixing the same thing that keeps coming back, and I am concerned there could be another root cause for the seal failing. Has anybody else experienced anything like this, or have any ideas on other things that could be the root cause?
