Been a few months of patiently waiting but it's finally in.  Shipping tonight or tomorrow morning.
Heard one guy say to leave the front piece closed because snow can get in there?  Any truth there?
After watching the install video, think he must have been talking about the side plug (plugged in image)
I have not had any issues with my S&B CAI. I kept it just like the image. I never even realized there was a plug there when I installed mine. I’ll check when I get home. Don’t have truck with me right now.
This right here is plugged (can be opened).  She suggested leaving it closed for hotter and/or dusty areas.  One other Q, did you do this before an exhaust?  Didn't notice it at first, but appears they added a silencer of sorts in front of the marked area.  Was kinda hoping for a bit more throttle growl
InkedCapture.thumb.PNG.f090868412e04858ede6195a63b1e88a_LI.jpg.4e3f6fff4e1e0600cd47c881e849724e.jpg
I see where it’s at, but I believe I left mine alone. Will check for you when I get home. I installed it after I had my Corsa exhaust on, because it was on back order for over 2 months. It has a deep growl to it and I can hear it sucking in air when I step on it.
I stand corrected. I do not have the plug in it. I have about 5k miles on it so far and filter looks good. I live in Iowa and we have had 2 snowfalls already.  One was over 6 inches so a lot of $h!t in the road. No issues.
Nice, thank you for the insight on the sound and leaving that open.  Now, if I can get her to come install mine
  • Haha 1
Just to help out---I too finally received mine last week after waiting 3 months and installed it this past Sunday. I did put the plug in mine as recommended but of course I don't have snow issues here in central Texas. I was worried about engine noise as others had mentioned in other forums but I did not notice anything different. I do however have a Flowmaster FlowFX kit installed which drowns out a lot of noise but still had no noticeable difference. Motor seems to be a tad more responsive and pulls a little harder. Hadn't drove it enough to notice MPG change yet, we'll see!
Checked that out and yeah, bet the exhaust is playing a big part in not hearing it.  Mine is boneeee stock at the moment.
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
