34 minutes ago, It's Tim said:
Nobody buys a truck for "fuel economy". Regardless of price I'll continue to consume as much fuel as I please.
No and yes. It's far from the most important for me but it's a nice satisfaction feeling to get better mpg than worse. And it's always nice to "justify" things/purchases/etc in your head.
It's not about fuel $ savings for me... what I really love is being able to drive further (especially while towing) and not have to stop and fill up with gas as much. Not having to stop at all... or stopping once instead of twice is what really pleases me. TIME IS MONEY baby. The catch with these Silverados/Sierras though is the freaking small fuel tank. While it doesn't necessarily "need" to be any bigger I really wish it was a 30 gallon instead of 24.
I can make the 350 mile trip from Houston to New Orleans (which I frequently drive) on one tank of gas towing my trailer. No need to pull off and stop just put it in Drive, get there, crack open an Abita and relax ?
Edited by Duramax3oh
9 minutes ago, Duramax3oh said:
I don't like to use the instant mpg reading other than to get a vague idea of the general range we may be talking about.
I take a lot of long highway trips and prefer to set cruise control at different speeds and then see how the 25-mile avg and 50-mile avg readouts look. It's hard to get any more accurate than that IMO.  Particularly when you do that on I-10 in Texas and Louisiana... there is NO DOWNHILL ?
As well as grade, it's also important to note/track any wind or traffic as the both also impact fuel economy.
Setting adaptive  cruise and following a smooth sided semi-truck/trailer can make a big different in the economy. Of course it depending on the trucks choice of speed, it might make the trip longer  ?
Go ahead and follow that smooth sided semi, if you have ever seen what a blown tire from one of them can do to a vehicle you might change your mind. I don't dally around tractor/trailers any longer than needed
  • Like 3
This right here, especially if you saw how 95% of them "perform" their pre-trips.
Don't necessarily trust the instant or average fuel economy numbers as shown on the screen, as they can be overoptimistic to give the owner that warm fuzzy feeling.  Hand calculate your fuel mileage for a few tanks and then you'll know exactly what you're getting.
Don't need to be THAT close...
This is extremely good advice. My Fords in the past have always been on the optimistic side when real mpg was lower. I've hand calculated at minimum 20-25 times with this Chevy though and only ONCE has the hand calc been lower than what the information center has displayed. I've been pleasantly surprised
On my truck I'm getting 2 to 3 mpg different then what it says on the economy numbers. My truck says I'm averaging is between 21 to 22 mpg and I hand Calculate is 22 to 25 mpg.
one thing is for sure as I have said this before , GM really dropped the ball not only going smaller tank on the T1s and also at same time not offering a buy up bigger tank option like Ford, Dodge and Toyota do.  I cannot understand their reasoning.
On 12/16/2020 at 10:05 PM, 71_340 said:
Mine is brand new.  DIC shows 24.5 MPG average for the first 180 miles, 50/50 highway/city.  It's cold here so I used the remote start twice.
Keep in mind that it take time for the engine to break in, it's cold and winter fuel (diesel or gas) carries less energy.
Update on my initial displayed MPG.
Today I filled the tank for the first time after putting a little bit over 500 miles on my new truck as follows.  The first 100 miles between 65 and 70 on the Interstate, then 150 miles local (city and secondary roads), yesterday 250 mile round trip with 3 passengers, adaptive cruise set to 75.
DIC showed 24.4 average, hand calculated it was 24.7 MPG.  Not bad for a new engine; I am not sure if the truck went through a DPF regeneration cycle or not.  On my list is a gage so I can monitor DPF soot level and when regeneration starts.
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
