I recently traded my 19 LT for a 21 RST. On my old truck I could open and close every single door several times and afterwards my truck would auto lock as soon as all the doors were shut. On my new truck I’ve noticed that it doesn’t always do that even tho I believe I’ve enabled all relevant settings in the infotainment system. I don’t have the rear door lock buttons on my 21 like 19 had so idk if that may have anything to do with it?
I seem to be experiencing the same thing - or at least similar.  I have a 2021 GMC AT4 and the doors automatically lock most of the time.  They sometimes do not lock - just often enough for me not to trust it - ever - so I'm constantly manually locking the doors just to make sure.  I originally thought it was because I was not exiting the field soon enough but I can't seem to recreate it in any form or fashion.  I am taking my truck to the dealership tomorrow for some other work and plan on having them look at this also.  I'll report back once I get an answer from them...
I've had my truck for about a month and have noticed it not lock a couple times. It seems to occur more when the last door I shut is a rear one. Mine is set to beep the horn when locking so I just always listen for that when walking away and press the button if needed.
Sent from my Pixel 5 using Tapatalk
Same here, always a rear door when it fails. It never happened on my 19
I disable the auto lock system. Personally don't like it.
If you want the truck to lock by itself a few seconds after you get out so you don't have to hit the door button, there is a setting in the "vehicle" app in the radio settings. I believe it is under lock/unlock settings.  It's called passive locking and you can set it up so it does it silently or does a horn chirp so you know it is locked.
If setting up passive locking doesn't work, then it may be a glitch.
I have used the passive locking system with the horn beep for over a month now.  It hasn’t failed to lock yet with several tests of repeated unlocking and opening front and rear doors.  I will probably continue to test with horn notification for another month or so before I trust it enough to turn off the horn notification.
Eastex
So, what did the dealership say?
I just got it back last night - the had it since Monday to fix the passenger side mirror and a couple other items.  They said the door locks were "functioning as designed"  I suspect the just stood there while it locked (successfully) and moved on.  I'll keep pursuing it on future visits.
Thanks for the follow up. I am afraid that's the nature of intermittent issues and diagnosis.
I wonder if the passive locking is being overridden or signal blocked some way. I know the passive locking can be temporarily overridden by holding the unlock button down (there also may be some unpublished way). When this happens it won't passively lock until the next time the ignition switch is cycled (truck started). I manually override mine when cleaning or working on/in the interior. Or maybe some radio signal/interference that doesn't allow the system to recognize the FOB has moved out of the proximity range? You noted a correlation between failure to lock and a back door. Any other consistencies, location of occurrence, could a second FOB be near (significant other's purse or pocket) amount of time the door is open, etc., etc.? When it doesn't lock passively does it easily lock using the FOB?
Next time try walking up next to the door (to establish signal) then walk far enough away that it should lock. If it does lock, it may indicates a signal issue. If that doesn't work try opening and closing the door, or doors, then walk away and see if it locks. it may indicate the system is not recognizing all the doors are closed (or maybe all the doors aren't closed). Last try, starting the truck, turn it off, exit and close the door, walk away and see if it locks. If it locks, it may indicate the passive locking was overridden somehow and reset by cycling the ignition. Or any/all of this could be useless as I have no clue what I'm talking about.
I use passive locking all the time on both my truck and Camaro, so far without issue. I would miss the convenience if it wasn't reliable. I never have to think, did I lock the doors?
Please let us know if you get it figured out.
JMHO
No expertise implied or expressed
I know its been a while since this thread was updated but I recently purchased a '21 Silverado RST and I am experiencing a similar issue... I had a theory that the auto lock was overridden if a door was left open too long so I ran the following test... During the entire test I did not leave the range of the key fob so that may be another variable that was not taken into account.
Unlocked the truck with the driver door handle button. I then opened and left the rear driver side door open for about 40 seconds and then shut it. The auto lock did NOT engage.
I repeated this same experiment for 30 seconds, 40 seconds, 50 seconds, 1 minute... Auto lock DID engage all these times.
I then left the the driver door AND the rear driver side door open for, 30 seconds, 45 seconds, 1 minute... Auto lock engaged all these times.
I wasn't able to test much more since this was done at my office in the morning when i should be working... I'll try more things in the future and comment if I find anything definitive...
    JimmyB4
    JimmyB4
  • Who's Online   0 Members, 0 Anonymous, 596 Guests (See full list)
    • Are you going to take long trips in it?  If so, try out the seats in the various trims. For me the lower trim level seats were not comfortable.
    • I have a 2016 that I bought new and still own. I'm around 129,000 miles now. The biggest problem was a transmission failure about 2 years ago around 95000 miles. No warning, just failed while driving down a back road. A reman GM transmission installed and it's been fine ever since. A few other minor problems along the way. I am in no hurry to replace it. It's been paid off long ago and do plan on driving this as long as I can.   I will admit I am leery about all the additional electronics in the newer models and feel that it is just more potential problems. I think there's actually more than I would have wanted in this 2016 but so far so good. I think even if something major like lifter failure happened, it would still be cheaper to at worst, drop a new engine in than buy a new vehicle.
    • I’ve own several successful businesses. I’ve bought homes and lived in different states. I’d witness several generations buy homes and survive in different economic circumstances. You get awful sippy when people have different experiences than you do. You live a life. I’ve lived a life. It seems our experience has been different. You can point out generalized statistics. Some people learn how to thrive when the odds are against them. Living in different states does make a difference in a persons quality of life and economic outcomes and opportunities. That’s a fact Jack. It’s my truth, my life. Hard work and long hours the right environment made my families life easier. And yes moving to a different state increased the odds of that happening. Stats are generalized. People who thrive don’t make excuses. They beat the odds. Others get mad and point to those statistics. I guess that’s you. My post pointed out how you helped people beat the odds. Somehow your panties got in a wad. Go figure.
    • Good question, I don't remember for sure but I believe it was the HD. I will check and get back to you.
    • Point of the post sir was that while both wages and cost are rising EVERYWHERE; the cost is rising faster EVERYWHERE than the ability to buy EVERYWHERE. We're not going down the location rabbit hole. I'm aware of what economic migration is. I've lived in four states including Texas.   It's what "Purchasing Power" means.   I'm not telling you what I think. I'm telling what the government, your government, data shows.   It wasn't an argument. It wasn't a suggestion. It was a statement of FACT. You are absolutely entitled to your own opinion. Your not entitled to your own facts. If you and I were, they wouldn't be facts.    fact /făkt/   noun Knowledge or information based on real occurrences. "an account based on fact; a blur of fact and fancy." Something demonstrated to exist or known to have existed. "Genetic engineering is now a fact. That Chaucer was a real person is an undisputed fact." A real occurrence; an event. "had to prove the facts of the case." The American Heritage® Dictionary of the English Language, 5th Edition • More at Wordnik   If you'd like to disagree call your Senator or Representative and let him know his departments are in error. But you and I? We are not doing this.
