OP put new ones in:
Alternator shorting wouldn't cause a lack of power when keying the ignition to accessory or run. You can straight up unplug the alternator and the car would still power up and even start.
Keep clearing the code and driving it to build more data on circumstances, the problem may become more constant, reveal itself or cause more symptoms that make diagnosis easier.
Some simple grounds from battery to engine, battery to frame, etc. using jumper cables might yield some clues.
Battery condition?
Alternator may have internally shorted - pull the power cable off the back if you suspect it.
I'd have a hard time selling it like this, I think. The CEL is very occasional but I can imagine someone buying this thinking it's going to get them from A to B and then it gives them trouble a few days later.
I still need to fix the starter...that's just embarrassing.
The front oil weep/leak...well, it's an old vehicle. I'd fix that if it didn't literally involve dropping the front axle or unmounting the engine and lifting it up several inches for access. It can leak for now.
Updating. My Avalanche went to my grandson because I got a smoking deal on a Ridgeline. The Genesis is over 150K and the Odyssey is going over 170K. Both needing nothing but maintenance so far. Don’t tell anyone I wouldn’t mind if the Odyssey will fail. I want a newer one. I’m stupid that way. I’m performance oriented. The odyssey is surprising. The Genesis is quick. The Ridgeline not so much with a 5 speed automatic and AWD. With heavy duty maintenance coming up I may move it along. Usually I let one of the kids have them. The fuel mileage and maintenance coming up. I’ll sell or trade it unless I just do the maintenance. I always had a Chevy of some kind in my yard. I’m not feeling it with the Ridgeline. My brother in law has a Yukon with a 4.8 and no cylinder deactivation. It’s a pretty clean high mileage example. He living in Oklahoma now needs an AWD for emergency’s. His driveway is very sloped. I may suggest a swap. I’m chewing on it while looking around.
Register a new accountSign in
