The titan tank in my 2009 was best mod beside Efi live . Stock 26 gal tanked sucked while towing . The 36 gal is a lot better and unless I was pulling more often won’t change.
Edited by BB&Chiveon
Also On the Titan discloser it indicates the DIC will be inaccurate. I wonder if GM has come up with a reprogram  solution like ford did
Covid cabin fever got me, or I just got bored.  Ordered the tank from Amazon, I’ll post some pictures when it arrives and I’ll try to install myself in the driveway.
I've been thinking about it too. Anxious to hear what your thoughts are and if the gauges read correctly. Good luck!
Gage might read funny, but I'm sure you can get a real good estimate of fuel in the tank, or just multiply the gallons buy MPG and theres your range.
Range is just a guess on how you might drive in the future...
Several ways to estimate range, just as accurately as the estimate from the computer
Just like we did before there were 'guess-o-meters' for range.
We might even do it better, if we know that we are going to getting better/worse fuel economy due change in the grades/speeds/loads/etc.
I don't think you will have to worry about range of fuel with that tank, the limiting factor will be the range of your bladder. I wish they made one for the cclb as I do think 36 gallons is a bit light for a dually.
Sent from my ONEPLUS A6013 using Tapatalk
I received the replacement tank earlier this week.  The box Titan ships the tank in is about 15 inches too long.  Box was beat up pretty bad, gouges in the cardboard where the tank straps poked through and ripped the cardboard as the tank and straps slid back and forth inside the box.  The tank is plastic and was in surprisingly good condition.
I tried to do the replacement in the driveway, but I do not have the tools to disconnect the “quick connect” fuel line fittings.  I got the old tank down, but was unable to disconnect the supply and return lines.  Clearances under the truck would have made it hard to get the new tank in place under the truck, it hangs down about two inched lower, and the top sticks up higher.  Going to a diesel repair shop next week to have the tank installed, I will let you know how it goes.
The tank uses the original fuel pickup and level sender, so I expect the fuel level gauge to work as the original, just take longer to fall off the FULL mark.  I have an iDash to backup that reading.  I do expect the ‘Range’ calculation to be off in the low direction.  After all, this tank is roughly 55% larger than the original equipment, so I expect the actual ‘Range’ to be half again further than reported.  I think that is a good thing!
I was finally able to get the truck out for a road trip with the new Titan tank. After a fill-up I put 400 miles on the truck.  Usually takes 60-90 miles on the highway for the fuel gauge to come off the full mark.  The new tank went to 175 miles before falling below full, 40 of those miles were in town.  After the 400 mile trip the fuel gauge was at 11/16 of a tank.
The truck did a software update today, but I had to unplug the iDash from the OBD port before it would install successfully.  This is the first software update I have noticed the truck doing since I brought it home last February.  It has been to the dealership for a free oil change and tire rotation once.  They may have done an update then.
Photos show old and new tank installed from the driver's side, and a couple of the tank just after it came out of the box.
Only driven a couple of half tanks full so far, no problems.  I'm sure the miles to empty is off, it has not changed since going to the bigger tank.  A full tank shows about 700 miles to empty.  In 15K miles I have been averaging 18.9 MPG.  With a 36 gallon tank that's 680.4 miles.  With the larger tank it should be 1,058.4 miles.  The trucks computer is not aware of the extra fuel in the tank.  If you add about 50% to the trucks estimate, you will be closer to the truth.
Now that you have had it a bit of time - how do you like it?   the good (size), the bad (if any) and the ugly (if any).
Thx
The good is the extra 55% on-board.  With the cost of fuel going up, and the limits on credit card purchase at the local pump, that could be the ugly.  The bad for off road is, the lack of a tank skid plate and a metal shield between the driveline and the tank that the original equipment has.
All that being said, I’ll keep the Titan tank.  Can anyone use an original tank and straps?  Make me an offer.
    • Needs a manifold gauge hooked up and the pressures read.   If you don't have one, time to take it to a shop and have it diagnosed.
    • How rusty is the truck?     The transfer cases on these are an aluminum case.  If its anything like the rear diffs on the 2015-2022 Chevy Trax, those will corrode bad to the point it will push fluid through the housing via corrosion porosity or a crack from age/stress.    We have seen folks over tighten the drain and fill plugs on these transfer cases and crack them that way as well.    So I'd say its a 50/50 shot on re-sealing the case.  If all of the surfaces are good and its not badly corroded, they probably can re-seal it.  GM uses RTV to seal the case halves.   If they mention JB Weld, the issue is the case.  Be it a crack or corrosion.  JB Weld "might" hold if they clean EVERYTHING very well and drain the fluid out of the case and clean the crack and then seal it.
    • A while back, my truck (2018 GMC Sierra 1500 5.3) went in for an o2 sensor and routine service. The tech identified that my rear output seal on my transfer case was leaking, and recommended I have them replace it. At the time I didn't think anything of it, and had them do the repair. Less than a month later, I noticed that the recently repaired seal was leaking again. I called the shop that did the repair and they warrantied the repair and replaced the same seal again. A few months later, I noticed that once again the same seal leak had come back. It wasn't a great time to bring it in and I ended up just living with it for 6 months or so, noticing small (smaller than a baseball) size oil stains below the truck when it would sit for a while, as well as oil spray on the frame (to the point where it actually took the underbody coating off in that one spot). Finally got around to brining it in again, but this time I took it to a dealership service center since I am in a different part of the state for school. They identified the same output seal leaks and recommended they replace them. They also said there was no scoring on the inside of the transfer case, so it didn't need to be replaced. They chalked up the original repair failures to non oem seals and a job that wasn't done correctly. Now they called and said the seals are holding after driving/sitting for a while, but they found a very small leak in the middle, that they recommended they seal with some kind of silicone/jb weld (not sure what they are using). I haven't picked up the truck yet, but I have been reluctant about this whole repair process because I feel like they are just fixing the same thing that keeps coming back, and I am concerned there could be another root cause for the seal failing. Has anybody else experienced anything like this, or have any ideas on other things that could be the root cause?
    • I just started having AC issues with my 2012 Sierra. The symptom is blowing warm air on all vents.  Here is what I have checked so far. Compressor clutch appears to be engaging and cycling  I checked all fuses and relay, no issues. The only thing I have notices is the short line that comes from the firewall is very cold / frosted. This line is approximately 12 inches long. The coldness stops when it hits the first line connector. As far as AC compressor - At first start the clutch engages, runs continually, Short AC line frosts up. After idling for several minutes the AC line thaws out some but is still cool and the compressor clutch starts cycling on and off every 5 seconds.  Any suggestions on what to look at next would be appreciated.
    • Unless you are using a bypass filer system with a Beta of 1000 at 2 micron the commercial filters we have access to, even the very best of them, are poor at the 5 to 10 micron range the typical UOA test can 'see'. Point is there are some truly awful filters being sold A 45 micron Beta 75 filter is what Dyson used to call a screen door on a submarine. That leaves wear metals disconnected from filtration unless particulates are larger than the test can 'see' and yet captured by the filter...which is its job. If that is true then you have a major issue screaming at you.    The graph isn't mine. It belongs to GM and their study on this area. I looked up those studies and provided those SAE tech paper addresses multiple times. Machinery Lubrication displayed it and confirmed it. So if you have doubts about the study you'll have to take it up with GM Engineering. Just like you would have to take up a difference in opinion about the meaning a word with Webster or the length of on inch with the National Institute of Standards and Technology.      Most manuals have two schedules. "Normal Service" and "Severe Service". On it's face it tells you that oil in severe service is more highly stressed and doesn't "Last as Long". The item to bore in on is LAST...what does that mean?    It's the same question one asks about how long to toast bread. What are the inputs? Bread type? Wattage of the toaster? Distance from the elements? What is your preferred level of done?    So lets paint this with a broader brush. Oil is made up of the base and the additive package. The first is altered by heat and oxygen and later is sacrificial with a finite life subject to inputs toward that end. Resistance and supply.    It is the reason an OEM's OCI's are determined by 1.) the specifications of the recommended lubricant and 2.) risk management toward the bottom line. Those lubricants are also subject to cost effectiveness for the OEM.    There is a tendency for most people to believe that the OEM recommended oil rest on the top shelf and that anything other is lesser than. Truth is there are more oils on higher shelves than those on the lower shelf below the OEM's. They make that choice on COST TO THE OEM. Testing is incidental to the margin.    GM makes MONEY, the car/truck is a TOOL to leverage MONEY. Insert whatever car brand you like. Until you forking over a million plus COST not quality is the driver. Thus it is by DESIGN the recommended OCI's and oils fall well short of 'best practice protections'. Proof isn't hard to find. GM Ecotec I-4 2400 breather system and cold start PCM tuning has killed more motors and resulted in more litigation for those that used the 'recommended' practice than GM could bear. What was their response? SHORTEN THE OCI. TWICE.    I don't know how long to leave oil in an I don't know how the oil will respond to MY circumstances and because I don't and can't blanket statement or anecdotal evidence my way out of it.....I TEST and FIND the right OCI for the oil I CHOOSE. There is no shortcut but there is blind allegiance. I don't blindly trust anything.    People hear the word 'detergent' and believe that in the context of oil it means the same thing as laundry soap... Only in the most rudimentary way. It's the first additive to give up on you and they are putting less and less with each new API standard. Solvency can be used but it cost. Some unique undisclosed chemistries can be used. Valvoline R & P in example. OEM's haven't an interest in anything they see as limiting market participation. Whatever.
