i am trying to buy one for my new work vehicle and the company i work for is wanting to buy 14 trucks and all the gm dealers in a thousand miles are not helpful they are blowing us off like we are walking into or calling a dodge dealership asking for a gmc truck and we were told they will not order any trucks either it seems like gm got out of the 3500hd reg cab business
Edited by 94yj
From what I understand regular cab HD's are constrained for the balance of the model year.  HD crew cab production is being prioritized.  Demand is off the charts and Covid is causing production delays.  2022 ordering will start early, probably won't see many regular cabs until after 2022 production begins.  Oshawa coming on line will help.
I'm sure it has something to do with making more money on the CC higher trims .
Demand and covid are the reasons here.  We have to reduce some complexity to help the suppliers.  Its easier for them to make more of fewer variants than to spend time changing a bunch of times for a lot of variants.
#iworkforGM
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
