Im happy to try and search this if someone can tell me how. Im trying to figure out the best options and the best lift for my trail boss. Im thinking I would like to end up with 6"of total lift. When I look at lifts its confusing with the trail boss. Any help would be much appreciated.
As far as i can tell there isnt a 6" lift out for the trail boss right now. You'd need to get a 4" lift and that would be the equivalent of a 6" lift on a standard silverado. If you're willing to hold off for a bit ready lift has an 8" lift for the silverado id bet would make it over to the trailboss soon. That would give you 6" of lift over what you have now.
Thanks bud!  I am willing to hold off.....in fact I woke up this morning thinking I need to just cool my jets a little. I'm going to just try and level the truck for now and enjoy it.  I was looking a kit from ready lift to do just that but I had some questions about it as well in another thread. For the record I was thinking 6 total....so the 4" with my already 2" would be what I was looking for.  Thanks again!
If you go the route of a leveling kit make sure you get one that comes with new control arms. The factory ball joints aren't holding up. In the process of changing mine now.
scrap out shocks and block and throw std 6" lift on there......remove the shocks and its standard silverado, has lifted strut in front to get the height......you can just get whole new kit with shocks, no waiting.....sell stock kit on ebay for someone who wants to lift their standard truck....though they wont have longer cv axles, but they arent crazy expensive....
combing 2 lifts kinda seems idk.....a bit mickey mouse....just a thought anyway
Edited by Dunn
I've often wondered this myself.  I don't understand why all the lift companies state "not for TB/AT4".  Isn't the truck returned to a "standard" non-TB/AT4 when the front struts and rear blocks are removed?  The only difference would then be the longer CVs left in the truck.  So, why can't I just order and install any lift kit then?
That's the companys covering their butts for insurance purposes. You really just need standard length front struts to put on with the kit unless I'm missing something.
Having longer cv axles would be a good thing not a bad thing for lifted truck
But yeah take out stock TB lift you have stock silverado platform to work off of.......most good lift kits will give you new shocks, UCAs, diff spacers and block anyways....not cheapest route but certainly a better one i would think for life of truck, ride quality and performance..
Think it may be company's that are combining their spacer kits to the standard/TB existing kits is the issue.....thats why some say not for TB if its meant for standard silvy (using existing suspension)
a complete kit shouldn't matter cuz your replacing everything....
Edited by Dunn
What leveling kit did you end up going with?
It's a Zone 1.75" kit with uppercontol arms. It's coming in Wednesday. It uses preload spacers and a small puck spacer on top of the strut to keep from over extending.
You're all over it! I was researching this this weekend....probably as you were writing your post lol. I will end up installing a 6" lift (maybe even 8") for a non trail boss. Will sell everything off my truck except my trail boss CV's.
So on the lift kit ....I want to take the time to have a complete plan as far as lift company I want to use. Shock company I want to use. Custom wheels and  tires I want. I want all of this in the garage and ready to install in one weekend. This is easily $10k and need to put in the time and research so there are no expensive mistakes.
Because the rake in the truck is bugging me.... For now Im just going to level the truck with a kit that includes upper control arms.
I had a thread started about RC 2" level/lift kit and RC says if you install their kit you should not use auto 4wd it could damage your truck.
They also say the same thing about their 1.75" leveling kit....dont use auto 4wd.
ReadyLIFT | 2019-2021 GMC AT4 and Chevy Trail Boss - 1.75'' Leveling Kit
So I'm wondering if this type of damage is possible with RC is it possible with all the brands of leveling kits? What would make the other kits any better?
It's an issue with the big leveling kits and actual lift kits. It's only an issue with auto 4wd. Something about vibrations
That makes sense......so I assume your not planning on using auto 4wd?
Edited by 21trailboss
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 512 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
