Finally got around to installing the Rigid Ignite flush mount LED pods into the rear step cavity. Took my sweet time and it ended up around 4 hours for install. Had a few roadblocks that took more time than expected and had to get creative.
Started off by using a calipers/tape measure to find the spot where I wanted them mounted. Used a pilot 1/16" drill bit to make sure the cutout was where I wanted it. 1 3/4" hole saw to fit the pods, then used a dremel to fine tune the slot for a tight fit. Mounting holes drilled after I had the correct angle and orientation.
Solder time! Added roughly 40' of wiring to the drivers side pod to run along the frame rail into the cab.
Connections secured with heat shrink on both 12V and ground, wire harness tape, and then finished with plastic wire loom so salt has a 0% chance of getting in.
Ran ~15' from the passenger side pod and soldered connections to drivers side pod. Wire loom/harness tape as well. Next step was the tricky part. Getting the washer and nylon lock nut onto the bolt took some creative thinking. You can't get your hand behind the bumper to get up access to the top mounting bolt, so I used a magnet to get the washer on the bolt, and taped the nylon nut onto the magnet and fed it thru the top slot. This was a PITA! A pair of needle nose pliers worked on the passenger side, but the spacing was tighter on the drivers side so that's where I had to get creative.
Mounted up! Ran wiring up through the frame rail zip tied to existing wiring harness on the drivers side. Up into the grommet which is underneath the drivers side footwell carpet, originally for the parking brake wire. Fed the wiring up into the dash.
These pods are meant to tie into the reverse light wiring, but I wanted a manual switch since I don't need them on every time I'm in reverse. In the future I may splice into the factory reverse lights and tie in a 3 way switch so that I can either turn them on manually, or they come on automatically when going into reverse.
Considering these take less than an amp of current draw each, I used an add-a-fuse into fuse 14 on the drivers side block (2amp, steering wheel back lighting) and used the accessory port on the add-a-fuse with a 2amp fuse. I only had ATM style fuse taps, so I will switch this to the RAP fuse (fuse #2) when I get around to buying some Micro2 fuse taps. This works for now since I won't need the 12V constant during the day when my lights aren't on.
Important to note polarity does matter while adding a circuit. Rookie mistake after about an hour of troubleshooting to find out I wasn't getting power from this fuse tap.. I had the dang thing in the wrong way ? The wire coming off the fuse tap should be going towards the back of the truck, not facing towards the engine bay.. Tie in the black wire from the pods and ground it, then use a splitter that goes to pin out #7, 12V wire from add-a-fuse goes to pin out #2, and the red wire from the pods to pin out #3. Switch LED only comes on when the pods are on.
Done! Clean install and does not drown out the back up camera. Will add night time pictures when I get a chance.
Link to switch panel build
https://www.gm-trucks.com/forums/topic/157013-what-have-you-done-to-your-k2-today/page/1416/#comments
Parts list:
Rigid LED pods - https://www.amazon.com/gp/product/B01HJ4G9QI/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Hole saw kit - https://www.harborfreight.com/1-in-2-12-in-carbon-steel-hole-saw-set-11-pc-68114.html
Add a fuse for 12V power - https://www.amazon.com/gp/product/B01G8HUTCW/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
100' of 18 AWG wire (only used about 50' total) - https://www.amazon.com/gp/product/B07DDG7J9K/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
1/4" automotive wire loom - https://www.harborfreight.com/1-4-quarter-inch-x-14-ft-protective-wire-wrap-66985.html
Tesa wire harness heat resistant tape - https://www.amazon.com/Tesa-Fleece-Interior-Harness-Mercedes/dp/B017OECD7W/ref=sr_1_4?crid=74O4J9ZBJ3AV&dchild=1&keywords=tesa+wire+loom+harness+tape&qid=1612196519&sprefix=tesa+wire%2Caps%2C194&sr=8-4
Soldering iron, solder, heatshrink, terminal connectors, etc.
  • Like 3
Welcome to the "Rigid Lights in Bumper Step" family. I did mine a few years ago...No issues...Plenty of good additional lighting where its needed without washing out the back up camera.
Nice job on your install!!! I like the clean look of the switch on your dash. I simply hooked mine up to the factory back-up light wiring, so they come on anytime I'm in reverse.
I too made the multiple measurements behind the step. The depth of the light housing caused initial concerns of contacting the truck body. The outside edge placement gave me the confidence there would be enough clearance. I made a template out of the Rigid Lights packaging cardboard and taped this to back of the step. This aligned the three pilot holes for initial drilling (center for the 1.75" hole saw and the two outside holes for the mounting screws). The upper washers and nuts are a ******! I was able to get them on with long angled needle nose pliers. It was tight, and after I got the first ones on, I had to have a beer and "drink" about the next one. It took awhile, but I got them on. I might have had a few more beers!!!
See pics below...
Template I made, cut hole and light installed (same as the OP), light output from a distance, and light output looking back thru the drivers side mirror...
Great job. Its nice having lights in those cavities. I just noticed one of mine isn't working so now i have to figure out if its a light or wiring problem.
In case anyone is just coming across this for the first time, here is the original thread with a lot of ideas discussed:
Should have gave GMdog2 credit for this, as I stole his design ? Wanted something that wouldn't interfere with the usability of the step, and these worked perfectly. Snagged them on Amazon for about $105 and they are already back up to $130..
See pics below...
Looks awesome! I haven't taken pictures yet displaying the output in pitch black, so this definitely helps.
Funny you had the same issues on those dang top bolts.. On the passenger side an angled needle nose worked fine, but was too fat to get the right angle on the drivers side. I too had to drink on it while throwing some choice words at GM.. lol
So I haven't looked under my truck, but how hard is it to just remove the rear bumper with an impact instead. Seems like it would be easier than fighting with the nuts.
Just curious.
Just curious.
I was thinking the saaaame thing...
Just curious.
Haven't taken the rear bumper off before so not sure. I did think about trying to remove the actual step cavity, but tried that when I wrapped the rear bumper and it didn't go well lol. It maybe took an extra half hour of trying different things before I found something that worked, plus it's literally just two lock nuts. Still gotta be quicker than removing and reinstalling the entire bumper IMO
Edited by boettcher40
Looking into this whole bumper removal mystery today. I will report back with my findings.
    • A little girl said her prayers every night before bed and she asked G d to watch after each person she loved. One night she forgot to pray for her babysitter and her babysitter died. A few days later she forgot to pray for someone else and they died. The next night she forgot to pray for her dad. The next morning her dad was terrified. A bus almost crashed into him. He almost fell off a fifty foot ladder and almost wrecked on the way home. When he arrived home, he said I had a terrible day. His wife replied, “You think you had a bad day? My aerobics teacher died during class.
    • Nice! I had one here, once. The car dealer I used to haul for stopped by with it. That was over 10 years ago now. Those are SUPER rare these days, especially up here! Never even see them at car shows anymore.   https://postimg.cc/0rvcNZ1W
    • I remember watching one of the auctions on TV. It just happened that they had two little red express trucks. My brother bought one new in 1979, still has it. So I hung on to watch them cross. The retro redone example brought more bids and went for more money than the original one did. My brother has redone his 3 times and raced it. He’s now in the process of making more tame for cruising.
    • I always upgraded the suspension and steering components - bushings and ball joints, and had older cars that I could out-corner ANY modern car with. I used to be able to take my '78 Cutlass on off-ramps at stupid speeds and make the sharp MA corners without even squealing the tires. So much fun. My '72 El Camino must've had work done by the previous owner, since that thing seemed to handle even better than the '78.   I think the suspension & steering on the '72 was much more advanced than the '64, so that probably just made a good system even better.   I'm the same way with vehicles. I hate having to worry about the paint on my '93 W250 Cummins. I'm not used to that, lol.   https://postimg.cc/mzKr55sY
    • BEAUTIFUL!! That a Cutlass F85? Or 442? My side-ID skills are lacking thanks to failing memory, lol. Love that color & year, too!   Yeah I was never big on entering my own stuff, but I always liked seeing what everyone had, the rare models, and what's been modified. That was always fun. These days I have barely enough time to do what needs to be done at home.    Oddly enough, here in MA there are more car shows than ever in history! You'd think up here it would be dead, but it's bigger than EVER!          Took the 940 for its maiden voyage with the carburetor. At first I couldn't get out of the yard! This originally had the "Bosch" system (our other 940 has Regina - single fuel pump in fuel tank, and space-age-looking ignition coil on driver's fender) - that has dual fuel pumps. One in the tank, and one under the center left of the vehicle. I had unplugged the external one thinking I wouldn't need it with the carburetor ... but the way I have the pressure regulator hooked up, 90% of the fuel volume is going back to the fuel tank, so cranked all the way down, the regulator is only supplying a hair above 3.5 PSI to the carb. Turns out the in-tank pump (15 PSI alone, instead of 45) couldn't handle the load. Plugged it back in and went for a rip. Ran great!   Throttle response is always amazing with carburetors. ZERO delay that no FI system can reproduce. Also fires up in half the crank rotations as before. Low end power was DRAMATICALLY improved. There was an ongoing lean issue with the FI that I got tired of figuring out, so this is a MASSIVE improvement! Above 50 MPH on hills it feels SUPER weak, though. This is more than likely due to the timing not being advanced enough by the computer, since it believes there are multiple failures. I can live with that through the winter. Will keep me from passing slowpokes where I shouldn't and getting speeding tickets at least. 😁
