Hey guys with spring around the corner
I am starting to plan some spring projects. Behind my fence is a tree line that looses it leaves in fall. I want to add some taller bushes/trees just in front of the tree line to eventually grow and provide a natural fence. One day the field behind me will most likely be a warehouse
Any suggestions? I’d say 10-15ft tall I’d like to stay at and I have about 100 feet wide in my backyard (spacing?)
Thanks!
Ur a funny guy Ryan.
Sent from my Pixel 3 using Tapatalk
Is that still your property between the tree line and your fence?
Can't help you on what plant to use. What grows/survives here won't make it through winter more than likely at your place. Red Tip Photinia works great here, but does have a fungal issue sometimes that is handled by spraying. They grow fast, thick and tall.
Here's this to look at at:
https://www.instanthedge.com/fast-growing-hedges/
Edited by txab
blackberry bushes have thorns, and fruits in summer, they handle the freezing weather up in vancouver and europe
Edited by flyingfool
Yea don’t want anything with thorns [emoji51]
Technically i think it’s the HOA property but if I drop in some small evergreen type pins would they know? I thought about right in front of the tree line. There is also a metal cattle fence running between the tree line
If you can see my flag that is where it is staked
Kinda like this but maybe not so close
Together and only growing 10-15 feet
Yea, emerald green arborvitae do a good job for what you are looking to do. Just have to patient with them, and make sure to prune them when they start growing.
Otherwise the snow will beat the crap out of them until they have a good "backbone".
Spacing is very helpful, too close and they will die, too far apart and it takes forever for them to fill in. They are a great bush to sculpt, very easy maintenance.
24 minutes ago, garagerog said:
I second the arborvitae but your HOA will know for sure they didn't get there from errand seeds blowing in.
Blame it on Johnny Arborvitae.  :D
I’m not worried about it, I’ll probably put them in front of the trees anyways. There is an evergreen in the picture i posted it’s random only 1 there lol. This was all Farm land previously too
Here is a pic from the summer
Hedge bushes. They’ll grow as high as you want and stay green.
I’d prefer low/no maintenance also
  • 1 month later...
b95861b90f44768c8f415a2800e4f7bb.jpg711a684036eb6cb440f0adb02f019b42.jpg60baba8d92f36e2a0eff846e4078147c.jpg
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 461 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
