Exterior light function depends on how many times the the Cargo Lamp button is pressed:
If you have tow mirrors, the LED's in the mirrors also operated, as is the light in the tailgate handle that shines on the hitch area.
Basically,
first press is all on,
second press shuts off mirror lights and leaves the rest on
third press is all off
Exterior Cargo Lamps
The cargo lamps provide more light in the cargo area or on the sides of the vehicle, if needed.
The lamps inside the pickup box, in the tailgate handle, for the hitch, and/or the cargo mirror lamps also turn on, if equipped.
If the vehicle is in P (Park), R (Reverse), or N (Neutral) the Cargo Lamp Switch causes the lights to cycle through the following states for each button press:
 Initial Press:
- CHMSL/Cargo Bed Lights - On
- Cargo Mirror Lights - On
- Cargo Switch Indicator (if equipped) - On
Next Press: (if with in 5 seconds of the previous button press):
- Cargo Mirror Lights - Off
 Next Press:
- CHMSL/Cargo Bed Lights - Off
- Cargo Switch Indicator (if equipped) - Off
Well...  it didn’t work.  I installed the Rigid lights in the bumper and tied them into the bed lights....  when I hit the cargo light switch,  the bed lights blink twice (not the cargo lamp) .  And then the bed lights shut off.  As do my Rigid lights I just installed.  I assume the system is to smart and feels to much draw?
any suggestions?  I really do t want to run a whole new circuit.
You could run a fused 12v wire to a relay and have your cargo light switch control the relay. I don't know which wire it is, but there should be full time 12v in the trailer harness.
Tried it.. stayed on in reverse but not drive... and the DIC said "Cargo lamps disabled" when I tried to turn it on whilst in motion.
And I'm OK with that for now.  As long as I can use it as a utility and back up I'm fine with that.  I'll have to find a full time 12v to wire them to.
Where should to fuse go..?
Got it done.  Power from the bed lights to the relay and 12v from the trailer harness.  Works exactly as I wished.  Thanks gang
