Hi, I just picked up my first new truck, a 21 2.7l Silverado custom crew cab.  So far I've been impressed by the little motor, it seems pretty efficient and for non towing duties it's just about perfect.
I do have some questions about it though:
  • Is there a catch can for the 2.7l, where do I buy it, and are there online installation directions.
  • What is the proper tire pressure, it was set to 40 from the dealer.
  • I need the 12v outlet in the cab to turn off with the ignition so I can run a dash cam.  Any hacks to get this to work?  I was told it stays on full time which eliminates the use of a dash cam.
  • Any good mesh nets that I can use under the rear seats (crew cab) for storage?  I need something portable so the large plastic trays probably won't work.
  • Does it come with wireless android auto/apple car play?  I have the lower end screen (7"?) if that matters.
  • Can I add a factory brake controller, the truck has the wiring and receiver for towing but it didn't have the brake controller built it.
Loving the truck so far, I'm going to daily drive it for a while to see what kind of mileage I can squeeze out of it.
Nice truck and congrats,...I have really been impressed with our 2.7s in our fleet of trucks.
If they didn't remove it just open the drivers door and read the sticker on the B pillar for the tire pressure. Should be like 35psi for cold tire pressure.
Thanks, I'll do that!  I've read people are getting closer to 24 on the freeway with the latest iteration, with the one trip I took it seems possible.  Didn't have time to drive it today so I detailed the interior, can't wait to get the leather installed.
Look at this video  to learn how to change from always hot to Accessory. Super easy, just move the fuse one over.  Not sure on anything else other than no-go on OEM brake controller. Will need 3rd party.
Just thought of another question, is there a way to tell when the 2.7l goes into 2 cylinder mode?  My vette shows it on the DIC but I haven't noticed any sort of icon on the Silverado.
Congrats on the truck. To answer a few of the other questions, the 7” does not get wireless CarPlay/ AA.
There is no way to add the factory brake controller however GM sells one in the accessory store that I’ve seen people mount in the same slot. Might be the best option.
And 40 PSI is way too high. My truck on 20” wheels calls for 35 PSI.
Thanks, that is really disappointing about the wireless AA.  There is a bluetooth dongle that will do the same thing but it would be nice if it were built in.
I'll look into the gm controller, I don't town often (hence the 2.7) so I can do without for a while.
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
