Add another one to the list. 2021 Sierra Elevation 3.0 Duramax  Happened twice in the first 1,000 miles and disappeared for a couple thousand miles. Now with 5,000 miles on the truck, it’s happened 7 or 8 times. Always starts right up on the second try.. for now.
Edited by WontStart
Coherence
Just had my second long crank no start , first one was at about 230 miles, this one was at 5690 miles. Second one I had run into a store for about 15-20 min like others have reported.  But I had done this several times before with no issue.
Have you or the dealer tightened the four screws that sandwitch the fuse box together?   I have tightened mine to the recommended 53 in lb and then a few weeks later they were loose again and I retightened them.    I think the plastic  pieces are deforming, probably aided by the high heat of the nearby exhaust reactor that gets super hot during regen.     So far I only had one event and none since the first time I tightened the fuse box bolts.    It would be interesting to see if a truck like yours with multiple events has loose fuse box screws.   I'm sure GM emphasizes the tightening of these screws because my fuse box has hand made, check marks by each screw.    It is probably a final assembly QC check.   They seem to work loose over time.   Nearly all circuits dealing with the engine controls involve this fuse box.
Not trying to answer for them, but I was a big cheerleader for the Fuse box bolts as after mine did it the first time I found mine way out of spec.  I too re-torqued them a few weeks ago, they were loose.  But after my truck did the crank-no start yesterday when I got home I pulled out the torque wrench and all 4 were still at 53 in-lb.
Bummer
So weird that I had 2004 Colorado that was key start but would do a similar long crank no start. Never failed to start within 15 mins. Was a great home depot beater with 160k mi when I sold it a few yrs ago. GM never had a fix for it. Hope that brightens your day. 😉
Yes I’ve checked them a couple times. Never been loose and I still get the extended crank no start. Really hoping it’s something simple and doesn’t require removing the cab from the frame like originally thought.
Edited by WontStart
5th crank no start today.  I have tightened the fuse box bolts.  Jumped out and checked them and one was no longer torqued correctly.  But as others have said I’m not confident on this or the exciter wheel.  Finally got video of it though.
Thanks for the comment.  Sure seems like GM has had enough time to figure out whats going on.  If they would just reprogram the crank cycle to running a maximum of say three or four seconds instead of 20 would be an improvement.   I would also like for the auto off/on button function to allow you to either turn on the function or turn it off and then hold that setting until you changed it.  I dislike having to turn it off each time you restart the truck.   When you have a truck that might not restart at a busy intersection shut itself off, you feel sort of stupid wondering what it will do when you let off the brake.
This is my first domestic vehicle I have ever owned.  I was debating between this (2021 1500 AT4) or the new Tundra.  My boss was raving about how great GMCs are.  I decided to take the plunge and got the AT4.  Right now I am wishing I had waited for the new Tundra, depending on how long it takes for them to fix this I may or may not trade in my At4 when the new Tundra comes out.
2019-2021 Chevrolet Silverado 1500 Autostop Eliminator
No experience with this product, but it is one of several ways to disable the auto stop/start feature. $99
At least if you trade for the Tundra you'll have a real screen instead of the little baby screen in the GM.
I experienced this for the 1st time last week.  2021 Sierra Denali with ~2,000 miles.  Mine started fine early in the morning ~6:00 AM and ran fine on my drive to work.  It sat at work all day and did it to me when I was leaving work around 4:00 PM.
Perhaps I missed it, but has anyone actually experienced it during a start stop event?
Trying to brainstorm this a bit, but it seems like the issue would have to be tied to the ECM not giving the OK to feed fuel to the cylinders.  I say this because the engine is getting air (no clogged air filter) and it doesn't have an ignition system (no spark plugs) to worry about so it really points to a lack of fuel to start the engine.  A sensor or condition must be telling the ECM to not distribute fuel to the injectors for some reason.  For example, on my GM gas cars, the engine will not start if I mash the gas pedal to full throttle while trying to start the engine as I do this intentionally to prime my oil pump on the first start after changing the oil and filter.  My 3.0 no start issue seemed very similar except that I did not have my foot touching the throttle pedal.  It's probably something simple causing it...
Edited by V8Chevy
Has anyone tried replacing the key fob battery? Maybe an intermittent weak signal or interference. I’ve replaced mine but not too confident this is the issue.
    Tbhats2130
    Tbhats2130
  • Who's Online   0 Members, 0 Anonymous, 1,967 Guests (See full list)
