I have a little over 5000 miles  on my 6.2  On 6.2L engines (RPOs L87, LT1, LT4 and LT2) built from June 1, 2020 to October 7, 2020 does anyone with that build date have a lot of miles and no problem yet?
2019 High Country, Purchased 12/23/18, 30k on it currently.
2020, 6.2L, 10 speed, AT4, purchased about June last year. 13k miles with no engine issues.
Had a weird situation once where the engine wouldnt crank or start. Disconnected the batt and reconnected. Was all good, probably electronics related. Hasn't happened again. [emoji2369]
I also  put on  a pulsar lt, so far so good, gas mileage went up from 16 mpg to 21 mpg. If you have the extra coin I highly recommend it. Hopefully my valve springs are good. Thanks to all the guys that have posted
2019 with the 6.2 and only have 18k.  Since we moved and l lost my job the miles will not be adding up so fast as they did before.
Can you expound a bit on this HUGE mileage increase? How has your driving style changed before and after? What stage tune setting do you get this mileage increase, 1-5? I assume this is highway MPG? What speed do you run?
Thanks.
Thanks.
On the hwy at ~10-15 over the speed limit I average between 19.5 and 20 mpg in my 6.2. Lifetime right now is about 18.5 through 4500 miles. 45c72549f0330ef630553f4bea5c4eec.jpg010cc22a49f8f1d55b97f4bfb7318177.jpg
2021 6.2 LT TB purchased in with 4K miles. Valve spring went out at 197 miles. A month later all the springs were replaced and I haven’t had a big issue since. My parking sensors still kinda work sporadically and the dealer hasn’t been able to fix it. Although lately the error pops up less and less.
For those getting 20mpg, are you guys/gals driving super conservative/all highway?
I'm at about 13mpg mixed. 18mpg running cruise control on the highway...trying really really hard.
I'm on my second engine here and neither of them hit 20 over a long haul.  I have a TB so it might factor in a bit.  To @awesome barney, I think it has a bit to do with how he was driving and/or where.  This is NOT a programmer/tuner.  It only modifies the info coming to and from the control modules.  If this were true, GM would be hopping all over it to keep their overall MPG down.
It does is no good to know how fast over the speed limit you’re going. What’s the speed you are traveling? Here in Utah the speed limit is 80 mph so your mileage is going to be much different at 90-95 mph as opposed to somewhere that has a 60 mph speed limit and that person is running 70-75 mph.
    DaleB
    DaleB
  • Who's Online   3 Members, 0 Anonymous, 1,184 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
