Hello.
I'm new to this forum but I've been reading on in for a while now. There is some really good information in here. I'm hoping someone may have run into the same issue as what I'm having.
I have a new 2021 Sierra 1500 work truck with only 3000 miles on it. I've added after market parking sensors to the rear bumper and tapped into constant 12v power on the round trailer connector. I'm not sure if this is coincidental but I noticed a day later that none of my TPMS senors register and the Key Fobs only work at a very close range? Weird huh..  I've read that the TMPS and Key Fobs work together? Has anyone else experience this issue where none of the TPMS sensors register and the Key Fobs only work at a close range? I do have an appointment with the dealer next week. I've also tried to reset the TPMS sensors using the procedures in the owners manual.
Edited by mactac
misspelled word
13 minutes ago, mactac said:
Hello.
Can you untap your 12v source and see if the issue goes away?
Gmarsh.. Thank you, I think I just failed basic troubleshooting 101. Disconnected 12v at my tap and reset the TMPS  and everything works including the Key Fobs. I never would have expected that from a tap at the trailer plug!
Do you know a good place to get 12v at or near the rear bumper?
Edited by mactac
misspelled word
I'm using a tadibrothers aftermarket kit that allows sensing for both the front and rear sensors. It has triggers for reverse and breaking, it states you need constant 12v for the controller so the triggers decide which sensors are being use. This is why I tapped on the 12v trailer connector.
Thanks for the help.
Could it be the brain box that is causing the problem? Sounds like the wireless brain box is on a frequency close to that of the truck wireless.
Yes, I agree and believe the wireless brain is like you said " is on a frequency close to that of the truck wireless" I rerouted power directly to the battery and I have the same results. I'll be calling tadibrothers tomorrow.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
