Hello.  I am new to the forum and found a unique problem with my truck - 2020 Silverado 1500 High Country.
I have an iPhone 12. It pairs with the truck and works perfectly fine when I start the truck from within using the push button.
It does not work properly if I remote start the truck with the key fob. Everything works except the voice commands.  It says…I can’t find a phone. Pair or connect a phone and try again.
The phone is connected. I can receive incoming calls, all contacts are visible and the infotainment screen says my phone is connected.
I opened a case with GM. The had me reset my phone and my truck. When it did not resolve the problem, they sent me to the dealer.
The dealer could not replicate the problem because they did not remote start the truck.  I sent them a video to confirm the problem. They said it was my phone so I paired my wife’s phone. Same problem. They then told me it is an iPhone problem. I paired an android and had the same issue and sent all videos to the dealer.
They now want to replace my radio based on feedback from DCM and other TAC research.
My question is this…I know there are lots of issues with Bluetooth and these vehicles. Does anyone else have a similar truck that can try to replicate this problem?  GM says my findings with remote start is an anomaly.  I am wondering if I stumbled on to something with remote start and GM needs to address the problem with software updates instead of tearing into my dash.
Thanks!
Edited by tsham
  • tsham changed the title to 2020 1500 BlueTooth Problem
I came here to tell you that if your vehicle toots are blue, then you're burning oil.  After reading your post I realized you're not talking about vehicle exhaust.
My answer to your question is:
2020 Trail Boss LT and Samsung Note 9; No issues.
I'm an idiot when it comes to technology, yet I managed to successfully fumble through connecting my phone via Bluetooth daily.
Perhaps the problems you claim to be widespread are end user related.  Not saying yours is, but you did claim there are a lot of issues.
LOL…yea, I noticed the typo and fixed it. Thank you.
I only claim there are numerous problems because the tech sent me a screenshot from DCM where they said they deal with multiple Bluetooth tickets each week.
Do you remote start your truck?  If so, are you able to use steering wheel voice commands to make a call on your phone?
Appreciate the feedback.
I have a 2019 Sierra 1500 AT4 so maybe not relevant.  I've not had problems with the phone connecting after remote start but I don't remote start that often either.  I do have issues about 1 a month where after starting my truck, the phone doesn't connect at all.  I get the "No phone connected' screen.  I can try and connect it in the screens and that sometimes work but about 1/2 the time, I have to turn-off and restart the vehicle for it to connect.  No definitive pattern to when it happens.  Just like the "SD card removed" message on the nav, no it isn't, the vehicle just seems to fail to recognize it one in a while, that's like every six months for me.  To me it seems like the system just get out of sync some times when starting, like a cycle in one of the computers took longer than usual the the next system can't find it and moves on.
Thanks for the reply J2.  Interestingly enough, my phone always shows connected on the infotainment screen. However, I like your hunch about the system getting out of sync as I have the same theory about the remote start.
When the vehicle is remotely started, it has to limit vehicle functionality. Once you enter the vehicle  and push the button to complete the start, the truck has to activate all disabled items. My thought is they left voice commands of the list or the order of operations to start services is incorrect.  I am no software engineer, but since I can replicate the problem at will, I want Chevy to prove the radio is defective before they tear into my dash.
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
