While I was searching for info on flushing and changing transmission oil on the 8 speed (going from Dexron HP to Mobil 1 LV ATF HP), I found this GM technical service bulletin that is specific to the flushing and changing fluid on the 8 speed 8L90 transmission in various applications.  Although one would not have the special tools/equipment that GM has, it gives you a solid guideline on the procedure to follow as well as torque specs.  Hope this helps the DIY guys out there.
8L90 flushing proceedure.pdf
  • Thanks 1
  • 3 weeks later...
  • 3 weeks later...
Had my 2019 flushed by the dealer and the shifts are harsher than before the flush. It seemed better for the first 4-500 miles than got worse.
Be advised the 6sp, 8sp and 10sp each use a different ATF. Using the wrong atf can affect performance.
Automatic Transmission (6-Speed Transmission) DEXRON-VI Automatic Transmission Fluid.
Automatic Transmission (8-Speed Transmission) DEXRON-HP Automatic Transmission Fluid.
Automatic Transmission (10-Speed Transmission) DEXRON ULV Automatic Transmission Fluid.
ULV stands for Ultra Low Viscosity.
  • 3 weeks later...
how many miles beofre the flush ? im at 47000, dealer told me i needed it last oil change...part of the 45000 maintenance package
I think its recommended at 45k in severe condition by gm. So if you tow alot, idle alot, off road, live/ drive in mountains alot, alot of short trips ect ect. It's almost 100k if it's a highway queen.
According to the recommended maintenance interval in the back of the owners manual, for Severe Service the recommended interval is 45,000 miles for fluid and filter change.  I cant find an interval for non-severe service.
Edited by Gangly
I would do the 45 K, but that's me.
Same here, I'll prolly do a transmission fluid change at 45k, but not a flush.
    • And to top it off finally.......................these small GM LS engines are designed to SPIN!!!!!  Why choke them down to just off idle for cruising.  Why/how the "bean counters" have influenced the "engineering department" at GM is beyond me.   They took a solid platform of an engine and turned into a joke in OEM form!!!
    • Atlas,   Then following your logic we can't believe any story that the MSM produces? I mean it's documented they heavily donate to Democrat candidates. Vote Democrat in high percentages. Many MSM talents are married to Democrat politicians, Gov. employees. That goes for on-air and off, personalities and reporters. So they would all be biased and nothing they produce is to be believed in your mind?   Again the article simply was about ways AI can be used for pricing products. Nothing discounted current situations as a factor.    Again keep looking through your left/right lenses. I don't live my life that way.   And as a heads up this thread will be cleaned up again as much of this is off topic and is receiving
    • Yes, and only a couple years before delivery. 🙄
    • So you're saying toss the baby out with the bathwater? @txab posted article was her take on how AI can be used to manipulate pricing as it already does and has been rebuked by the judiciasry in housing. How AI can be and is used to maximize refinery or even Amazon operations all of which are true but because she is who she is; that makes what she says about what is true, false? Is that something akin to Pre-justice aka prejudice?    Look, I'm first in line to approach all information with caution just because we live in a world where people like to lie about someone or something with such a straight face and in such volume that it makes digging to the truth wearisome. Meaning I understand the skepticisms but if I were to toss out everything a person is for a view they hold then my pool of people to draw wisdom from would be non-existent and I'd be forced to reinvent the wheel daily. Not practical.    "Be innocent as a dove but as cautious as a serpent."    Test each word. Every good lie is part truth or no one would believe it. Find the truth in it and reject what isn't.    On this one, AI is being used to do what has been done by hand for hundreds of years already but at such speed, the point of a computer, that it is more easily monetized. This one wasn't that hard a lift.    I wrote a few formulas in a Lotus 123 program decades ago, a series of linked Macros actually, that allowed a daily inventory to be turned into a running P&L and production plan. Something that took three departments a week to assemble now took the time it takes to input the 'daily changes' in inventory. Later that was ungraded to the more powerful Excel program an and integrated with bar code scanning, inventory to supply was done once per shift. It had a huge impact on production scheduling, Seamless interruption flexibility, inventory error reduction, raw materials cost effective utilization and scrap reduction. Huge improvement in the bottom line. I spent months on that and AI could have done it in minutes. So yes, it not only can be used, they would be foolish to not try. The legality, ethics and morality are not the domain of AI. Humans need to keep a reign on it.
