So I just bought a 2021 Silverado Custom Trail Boss and wanted to see if anyone has taken their truck into the dealership to get a pair of Fog Lights installed, if so how much was the installation and was it worth it? Also if possible any recommendations for better Headlights, I've seen the review on
 https://www.amazon.com/H11-9005-HB3-Headlight-Bulbs/dp/B07MNG5S5P/ref=cm_cr_arp_d_bdcrb_top?ie=UTF8
and they are 50/50 so if there's anything else out there reliable. Thanks.
-Tony
I have a 2020 Custom and here is what I did:
~450 dealer installed fog lights
~ 2000 for swapping over to factory High Country LEDs with grill replacement
Sticking LED/HID bulbs works but the beam patter sucks. OEM is the way to go IMO
Changing to LED lights on my 2020 Silverado Custom Double Cab was my first modification.  The improvement was well worth the effort and the cost of LED lights in comparison to other mods was relatively affordable.  I purchased my lights from Amazon.  The high beams are Sirius branded and the low beams are CZ bulbs.  They fit nicely under the factory dust covers and the improvement in night time visibility is well worth the effort.  The low beams were relatively simple to install from the top, but the high beams were a challenge because of the longer reach needed to access them.  I found the easiest way to install the high beams was to pull the front wheels and partially undo the front fender liners to provide direct access.  My only question was whether or not the factory dust covers provided enough air space for the LED lights to run efficiently without overheating, and so far the lights have performed wonderfully without any indication of problems.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
    • We understand your frustrations with being unable to open your Sierra’s top inner tailgate, @smitty81503. Your concerns are frustrating, and we would like the opportunity to explore the best path of assistance to pursue their resolutions. There are many different factors that could be the root cause of vehicle concerns, and we handle each one on a case-by-case basis. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
