So I read a lot of posts on tranny problems on the Silverado 6 speeds. I haven't had any problems as of yet 112k and counting, but was wondering should I change the torque converter because a lot of people say to do it. If the answer to this question is yes. What replacement should be used.
If it ain't broke, leave it.
Did you do fluid changes?
Yes I have had tranny serviced at the dealer. No issues at all with the truck. Had all maintenance done at dealer at recommended intervals.
Decreasing interval lengths may be helpful after 100K. IMHO idunno if it helps, but I have had my trans replaced, unexpectedly.
If your truck has the 4.3, just give it the required severe schedule services and it will last a long long time. Forget the rest of this post. If however this truck has the V8 continue on.
https://www.sonnax.com/tech_resources/845-6l80-6l90-transmission-tech-advisory-consider-an-updated-converter-in-your-next-rebuild
I post this each time this question is asked and it is asked allot. Read it in it's entirety and really think about the "how and why" these failures happen. It's almost like asking if it's a good idea to continue bending a coat hanger as it hasn't broken yet, right? Then asking if you should replace it with the same type hanger!
Yes, it is true that those who service it regularly and treat it kindly get longer service life from their units...most...of the time.
This is just information you can use to make a decision with. I'm not telling you what or how.
Replace it. My trans looked great at 103 when I dropped the pan to do the filter. TQ converter went and wiped that trans at 106k. 5000 dollar repair at a dealer.
So I have 62k on mine and it was slipping a little. Just had the pan dropped and filter replaced.
shifts firmed up a lot, feels like a new trans.
Wondering if you guys that had a fluid done and then it went, noticed something similar
Better shifts after fluid is normal for the 8-speed (can't speak on others). If the TC chuggle comes back, that's also normal after a few thousand miles, but varies on how soon. For me, got on it one day entering the highway, and didn't shift; slight hesitation then dropped to low gear/high rpms, all at 65 mph. Beginning of the end.
I have a remote filter on mine , just changed it after 3000mi and was getting brass glitter flakes, I'm at 50,000 miles, all stock and t-stat removed. I am concerned since i only drive it on weekends and never tow more than twice a year.  gonna pull the pan on it soon take a better look. I have disabled the Lockup in 1-4th gears, so should be very little wear on the tcc, i think i'm having bushing issues instead
there is a relearn function on these transmissions which corrects for leaky pistons and slipping,  but only the dealer can do the relearn proceedure..
Edited by pokismoki
i used to get the chuggle on the 6 speed when i was moding the slip parameters. when i set the v4 mode , in TCC lock I zeroed out the slip and it would chuggle and viberate a lot, , then i went back to the 10-20 rpm slip in lock up and the vibes went away.
So question, if your trans is starting to do the bucking/slipping and fluid is burnt, is the trans salvageable or is it toast at that point? My suburban just started and was gonna take it in. Shop has been in business since 1971 so they know they’re stuff but curious if there’s any hope of not replacing the whole thing.
Got my answer. Was told they’d just replace everything out of precaution as they don’t know what the trans May or may not have digested so far. It sounds like it could be salvageable but not worth the fuss when throwing in a reman. $4-5k repair…. Ouch!
the high temps  in the converter kills the o-ring seal that keeps the lock up clutch pressurized.  this will exhibit a lock unlock condition, probably never lock up after the o-ring has shrunk and cant hold pressure
Good to know
    • Well one of our most reliable vehicles was sold yesterday. The first and only I gave for free to a grandkid. If they got skin in the game they take care of it. My wife bought new. Five years later my daughter got it to use. We got it back and gave it to our grandson after graduation. He did zero maintenance just oil changes. When the AC quit he drove his mother’s car rather than get it fixed. Instead he just bought a beater and sold the Elantra.
    • I usually do as well or better than the sticker for mileage. Usually better going west than east. North then South. Wind makes a difference. I’m not usually a conspiracy theorist. But it did dawn on me I’m going by the vehicle calculation. Now that would be interesting.
    • https://www.msn.com/en-us/autos/news/fuel-economy-stickers-don-t-tell-the-whole-story-aaa-data-reveals-why/ar-AA26ocHk?ocid=winp2fptaskbarhover&cvid=6a4122ea3dae47e5b8dfbed5d4fd3d55&cvpid=648f6b4fc2fa4eddb4c12893aeb957ed&ei=59
    • What’s missing in all this is patience and investment in the future. Buy a 170K starter home. Ten years later sell it invest in a more expensive home. Eventually you’ll have a 600K home and pay starter home payments. Buy a starter car. Maintain it well. Save the payments after it’s payed for then buy an expensive car if you desire. Buy a tumbler make your own coffee, pack your lunch. Cook your own dinner. Most importantly take care of your car.
    • People mislead themselves. Statistics are highly useful indicators.   Here's the tie-in to this thread. If an oil sample tests shows a wear indicator of 7 using cheaper ACDelco oil, and a wear indicator of 2 (lower = less wear) using a particular brand of Mobil oil, and wear has a linear relationship with engine lifespan, anyone could assume that Mobil is reducing wear by more than 50% (let's just say a 200% reduction for you red state people trying hard to do math) which leads to increasing engine life by 2x. Perhaps, in a vacuum, by itself, when dreamed by AI.   Yeah?! That's what the statistic is saying, isn't it?   No, it isn't. It didn't come out and say engine life is doubled. That's a very bad assumption, and a case of severe myopia by assuming something potentially untrue about the only data point in focus.   Average cost of a new car is 50k. You bet it is.   The median cost of a new car is more like 35k. Expensive cars are skewing the perception that "average" now means a $50k price of entry for a very average automobile. And that's not true. People who don't understand statistics twist the living heck out of them to mean all sorts of things they don't actually mean.   "Average" new car payment is $1000/month. Yep, it is. And in that number are all the $35k new car buyers who bring significant equity, and the $25k new car buyers who finance the car for a month just to get a rebate, and then pay it off. Know what isn't in that number? All the payments made by people who don't finance a car.   Picking one's own data point (don't have a car payment, never paid $50k for a new vehicle, my house cost $170k, I afforded a middle class lifestyle on $4.50/hr) is just a data point. Just like earning $25/hr in an area where the median home price is almost $1 Million is a data point. In fact, it's a lot of data points given that 80% of the US population lives in/around major cities. They're not idiots; the vast majority of them do it to make a living because that's where the big money is.   The highs have become higher, lows have become lower, and how your personal mileage varies is not truth for an entire country. At the same time you can't NOT acknowledge the data. While it doesn't paint YOUR personal picture, it certainly tints the reality that you also live in, as does your single data point.
