On 10/20/2021 at 9:25 AM, bird_dog0347 said:
There was another thread about this... Go out and start your truck but leave it in park, push the pedal to the floor hard, all the way then remove your foot and let the pedal come all the way back up, two or three times is what I did. This fixed the issue for me as well as others.
I'm glad you reminded everyone of this simple but very effective trick.  I learned this trick around the 4k mark from this forum and it is still good to go at 11k plus now.  Thank you for reminding us all and the new owners as well.  It really does work for some odd reason...
After pressing the pedal to the floor and releasing a few times, do you turn the vehicle off again and then restart? Or should that just fix the issue immediately? I’m experiencing this now and trying it out and it didn’t immediately change anything for me.
the brakes are definitely different than a 1/2 ton but are powerful....they just take more force
its a different system I believe
    smandy
    smandy
  • Who's Online   4 Members, 0 Anonymous, 457 Guests (See full list)
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
