Thanks for adding me.
I just got a 2021 Silverado Z71, I have been around GM trucks for over 50 years, this is my 1st new one.
I have a question regarding the cylinder cancellation (AFM), I have been doing a lot of research read that some 2021's did not have this due to the mico-chip shortage but nothing that will help me find if I do or don't . How can I tell if I have it or not? My engine code is L87. build date 3/21. My buddy's 2017 has a display that tells him what mode it is running in ie: V6-V8. I do not maybe this was dropped in the newer models.
The newer model trucks, beginning in 2019 I believe, do not have AFM, but a newer system called Dynamic Fuel Management (DFM), which operates differently than AFM.  A DFM engine will vary the number of cylinders firing between 2 and 8, unlike the 4 or 8 with AFM.  Consequently, the V4/V8 mode indicator on the dash has been dropped.  As far as to if your truck is one of those affected by the chip shortage, I'll defer to someone else who may have an answer to that.  It would seem to me that either the build sheet (available from GM), and/or the window sticker that was on your truck would say if your engine is equipped with the DFM system.
Thank you for the information, The window sticker just notes 6.2 ECOTEC3 V8. So I *guess* this has the DFM.
Call a dealer and have your VIN handy.
6.2 L87 uses DFM Dynamic Fuel Management.
Only the 5.3 L82 and L84 were affected by the semiconductor shortage.  Window sticker has a $50 discount on it.
All 6.2s for 2021 DFM is operational.
Edited by newdude
Thanks all, was hoping I hit the lottery and missed out on it.  My first 2021 had the 5.3 without out it, unfortunately I only had it 3 weeks and got hit head on by a red light runner and it was totaled so I got the 6.2 version when I replaced it.
Edited by WeGone
Even if the motors don’t have dfm I believe all the internals are there like the lifters and such to have it. It’s just the micro processors in the ecu I think that’s not. Correct me if I’m wrong plz. Also all 6.2’s have dfm as far I know gm hasn’t removed it from that.
Correct.  They engines are all the same, its just the afm/dfm is not active.
Lots of good info. here thanks.
So now that the newer trucks have dropped the display showing the V8-V6, other than hooking up a scanner there is no way to tell when or how many cylinders are operating at any given time?
There are 2 5.3's for 2021 -- depending on trim level of the truck
L82   Engine, 5.3L EcoTec3 V8 with available Active Fuel Management, (355 hp [265 kW] @ 5600 rpm, 383 lb-ft of torque [518 Nm] @ 4100 rpm)
1 - NOTE: Some models built beginning in March will include (YK9) Not Equipped with Active Fuel Management. With (FHS) E85 FlexFuel, engine includes Active Fuel Management.
this engine only used in base trim gmc, for chev it is used in WT and both versions of Custom
L84   Engine, 5.3L EcoTec3 V8, (355 hp [265 kW] @ 5600 rpm, 383 lb-ft of torque [518 Nm] @ 4100 rpm); featuring available Dynamic Fuel Management that enables the engine to operate in 17 different patterns between 2 and 8 cylinders, depending on demand, to optimize power delivery and efficiency
1 - NOTE: Some models built beginning in March will include (YK9) Not Equipped with Dynamic Fuel Management.
2 - Not available on TK10743 model.
3 - Not available with (PEC) Denali Ultimate Package. NOTE: Some 2WD models built beginning in March will include (YK9) Not Equipped with Dynamic Fuel Management.
1 applies to SLE, 3SB version of Elevation and SLT
2- applies to AT4
3- applies to Denali
(Chev similar)
YK9 Not Equipped with Dynamic Fuel Management
1 - Included and only available with (L84) 5.3L EcoTec3 V8 engine and (MQE) 8-speed automatic transmission.
2 - Included and only available with 2WD model, (L84) 5.3L EcoTec3 V8 engine and (MQE) 8-speed automatic transmission.
And for the 6.2 - all are DFM and YK9 does not apply
L87   Engine, 6.2L EcoTec3 V8, (420 hp [313 kW] @ 5600 rpm, 460 lb-ft of torque [624 Nm] @ 4100 rpm); featuring all-new Dynamic Fuel Management that enables the engine to operate in 17 different patterns between 2 and 8 cylinders, depending on demand, to optimize power delivery and efficiency
1 - Requires 4WD model.
    daveishi
    daveishi
  • Who's Online   6 Members, 0 Anonymous, 371 Guests (See full list)
