Thanks for adding me.
I just got a 2021 Silverado Z71, I have been around GM trucks for over 50 years, this is my 1st new one.
I have a question regarding the cylinder cancellation (AFM), I have been doing a lot of research read that some 2021's did not have this due to the mico-chip shortage but nothing that will help me find if I do or don't . How can I tell if I have it or not? My engine code is L87. build date 3/21. My buddy's 2017 has a display that tells him what mode it is running in ie: V6-V8. I do not maybe this was dropped in the newer models.
The newer model trucks, beginning in 2019 I believe, do not have AFM, but a newer system called Dynamic Fuel Management (DFM), which operates differently than AFM.  A DFM engine will vary the number of cylinders firing between 2 and 8, unlike the 4 or 8 with AFM.  Consequently, the V4/V8 mode indicator on the dash has been dropped.  As far as to if your truck is one of those affected by the chip shortage, I'll defer to someone else who may have an answer to that.  It would seem to me that either the build sheet (available from GM), and/or the window sticker that was on your truck would say if your engine is equipped with the DFM system.
Thank you for the information, The window sticker just notes 6.2 ECOTEC3 V8. So I *guess* this has the DFM.
Call a dealer and have your VIN handy.
6.2 L87 uses DFM Dynamic Fuel Management.
Only the 5.3 L82 and L84 were affected by the semiconductor shortage.  Window sticker has a $50 discount on it.
All 6.2s for 2021 DFM is operational.
Edited by newdude
Thanks all, was hoping I hit the lottery and missed out on it.  My first 2021 had the 5.3 without out it, unfortunately I only had it 3 weeks and got hit head on by a red light runner and it was totaled so I got the 6.2 version when I replaced it.
Edited by WeGone
Even if the motors don’t have dfm I believe all the internals are there like the lifters and such to have it. It’s just the micro processors in the ecu I think that’s not. Correct me if I’m wrong plz. Also all 6.2’s have dfm as far I know gm hasn’t removed it from that.
Correct.  They engines are all the same, its just the afm/dfm is not active.
Lots of good info. here thanks.
So now that the newer trucks have dropped the display showing the V8-V6, other than hooking up a scanner there is no way to tell when or how many cylinders are operating at any given time?
There are 2 5.3's for 2021 -- depending on trim level of the truck
L82   Engine, 5.3L EcoTec3 V8 with available Active Fuel Management, (355 hp [265 kW] @ 5600 rpm, 383 lb-ft of torque [518 Nm] @ 4100 rpm)
1 - NOTE: Some models built beginning in March will include (YK9) Not Equipped with Active Fuel Management. With (FHS) E85 FlexFuel, engine includes Active Fuel Management.
this engine only used in base trim gmc, for chev it is used in WT and both versions of Custom
L84   Engine, 5.3L EcoTec3 V8, (355 hp [265 kW] @ 5600 rpm, 383 lb-ft of torque [518 Nm] @ 4100 rpm); featuring available Dynamic Fuel Management that enables the engine to operate in 17 different patterns between 2 and 8 cylinders, depending on demand, to optimize power delivery and efficiency
1 - NOTE: Some models built beginning in March will include (YK9) Not Equipped with Dynamic Fuel Management.
2 - Not available on TK10743 model.
3 - Not available with (PEC) Denali Ultimate Package. NOTE: Some 2WD models built beginning in March will include (YK9) Not Equipped with Dynamic Fuel Management.
1 applies to SLE, 3SB version of Elevation and SLT
2- applies to AT4
3- applies to Denali
(Chev similar)
YK9 Not Equipped with Dynamic Fuel Management
1 - Included and only available with (L84) 5.3L EcoTec3 V8 engine and (MQE) 8-speed automatic transmission.
2 - Included and only available with 2WD model, (L84) 5.3L EcoTec3 V8 engine and (MQE) 8-speed automatic transmission.
And for the 6.2 - all are DFM and YK9 does not apply
L87   Engine, 6.2L EcoTec3 V8, (420 hp [313 kW] @ 5600 rpm, 460 lb-ft of torque [624 Nm] @ 4100 rpm); featuring all-new Dynamic Fuel Management that enables the engine to operate in 17 different patterns between 2 and 8 cylinders, depending on demand, to optimize power delivery and efficiency
1 - Requires 4WD model.
    d.lowrey
    d.lowrey
  • Who's Online   1 Member, 0 Anonymous, 2,944 Guests (See full list)
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
