Hi everyone. Former owner of 2 Silverado’s 03 and a 07 and I have a few questions hope you guys can answer to help me get back into trucks maybe.
I have the opportunity to pick up a 88 K truck, supposedly it’s a 4spd manual but everywhere I look the 88 came with a 5 speed manual not a 4spd manual, was this an option for the early 88’s?
I have yet to look at it and want to learn as much as possible before I waste time on it.
it’s been stored for 10 years with about 90k miles on it 1 owner who passed away, and his son wants to sell it.
Are these trucks collectors items? What would be a good price if indeed it has a 454 4spd manual 4x4?
are these 12bolt or 14bolt rear ends? Locking diffs?
any and all info is appreciated while I search.
Edited by Loneranger
Ask for the VIN number, that will tell us a ton about what it was optioned with.
A few guys on here work for dealerships, they can likely get you a lot of information. Even ask the person if there is a RPO sticker in the glove box or somewhere on the truck. That will list all options as well.
24 minutes ago, Loneranger said:
I’m waiting for that info, but the vin decoders I looked at don’t have tranny options or specifics Or do they?
Does not look like it.
Edited by JimCost2014
How far away is it from you?  May just as well go look at it. What are they asking for it?
20 min away but it’s in storage and the owner is 2000 miles away, waiting for him to fly out next week so I can go.  He’s in a midst of a divorce so talking to him is spotty at best.
    • Had a 2011 - replaced the brake switch - that was the problem, for me.
    • So, my 2021 only gets radio updates, right? If that's the case, my radio is doing just fine and probably better off without any updates, especially considering the problems I've been reading about after updates were performed.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
